250-500cc WR 300 cylinder sleeve
Discussion in '2 Stroke' started by Jay Hayward, May 24, 2013.
  1. Jay Hayward Husqvarna
    2009 WR 300
    Hi guys,
    Does anybody know where in Australia I can send by cylinder to have a steel sleeve installed, usually heaps cheaper than nikasil and can go oversize later on.
    Thanks in advance.
  2. Doug Piper Husqvarna
    Devon, England
    WR250 SM250
    Not sure if you can get a steel sleeve, normally the bore is re-nikasil plated when it has been worn/damaged.
  3. Jay Hayward Husqvarna
    2009 WR 300
    The local dealer in Canberra has quoted me $650 inc piston to get sleeve fitted and some of the machine shops in the states I have contacted have said they can do it but I'm tring to find the best price. (on wife and kids budget!)
  4. bdl507 Husqvarna
    New Hampshire
    99 wr360
    rd350 dr650 tt500 pe250 hondas lots
    In the states it was just over $200 the last cyl. I had done and last time I priced sleeves they were over $100 not installed. I have seen lots of different machine shops mess up a sleeve install. Also if you could get a sleeve for it (I haven't seen them ) can you get over sized pistons? (Just thinking out loud)
  5. Farmer John Husqvarna
    Santa Clara, CA
    2009 WR300
    92 WR250, 01 KTM 400MXC
    How much was it to replate?
  6. windsurf Husqvarna
    queesland
    I am sure oversize pistons aren't available just the usual graded sizes.
  7. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    most machine shops that sleeve should have a comprehensive list of pistons to suit your motor or source one that is correct for oversize, i know of a company that will make a piston for your size from a blank that they can machine to spec theyre in oz jp pistons
    so yes oversized pistons are avaliable even if custom. and 99% of any make of barrel or engine component can be re manifactured or replaced:thumbsup:
    i recomend sleeve as ive done 3000 miles odd on my existing one with no problems so far, dont be put off do research and find a good shop, call them and see what they say you can normally see who knows what theyre doing on the phone with some questions.
