250-500cc WR 300 gas mix ???
Discussion in '2 Stroke' started by PJBlank916, Dec 8, 2015.
  1. PJBlank916 Husqvarna
    TE 300 (soon)
    2013 Crf 450r KDX 200 CRF 450X
    Hey guys! I have a 2009 wr 300 and have heard many people complain and have problems with hard starting I run about 36:1 which people recommend around 50 :1 I have no trouble starting starts 3rd kick cold and first kivk warm its jetted perfect and smoke just the tight amount just a suggestion on jetting!
  2. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    if it aint broke don't try to fix it
    mix is a big one here, I run 50:1 but a lot of people run fatter
    if it starts and runs well what are you attempting to fix
    50:1 is 2% oil 32:1 is 3% oil, you add 1% more to your fuel than I do, where is that an issue
    Kam1 and ohmygewd like this.
  3. PJBlank916 Husqvarna
    TE 300 (soon)
    I'm not trying yonfixy bike lol just giving you guys some tips on what runs good for me
  4. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    kx65 ty80 rm80 kdx250
    IMHO thats to much oil[ if your using some good stuff] but if its already dialed to that mix and you have personal issues with it run it just remember if you switch to a leaner mix you may have to go leaner on your jetting people seem to for get jetting is an fuel/ air thing not a fuel/oil thing
  5. Eaglefreek Husqvarna
    Fayetteville,TN
    11 WR300
    Personally, I think it's technique. I've had a few friends try to start my bike and couldn't do it and then I jump on it and start it in one kick.
    shawbagga likes this.
  6. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    nothing wrong with more oil if you are set up for it. how much oil you run is directly related to how many rpms you turn how long. trail and tials bikes get away with much less oil while fast racers run no less than 40:1, usually 32:1.
    40 or 50 to 1 is a good compromise with good oil. i have run 40:1 for years and have been very happy with how my engine interiors have looked and performed..
    jetting is more important than anything
  7. justintendo klotz super techniplate junkie
    way too much emphasis is put on jetting changing with oil ratio....if you do the math its quite small.
    2premo likes this.
  8. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    I run 35:1 Half Av gas half race gas 110 octane.
  9. rufctr Husqvarna
    arizona
    1995 WXE250
    2003 KX500 - plated
    I run klotz r50 at 40:1 in all my bikes, no issues
    justintendo likes this.
  10. steadydirt Husqvarna
    Ontario
    2007 2002 wr 250 1994 wxe 250
    This is going to make you crazy;- 3% oil is 50% more oil than 2%....
    NCSteve likes this.
  11. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    I run 60:1 in my 2011 WR300, Motorex Crosspower.
    troy deck and 2premo like this.
  12. 2premo Husqvarna
    Northern NV
    3 of the people I ride with do that
  13. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    Right, and it would seem to me the more oil the better within reason. I'm more interested in oil injection than fuel injection on 2t. Variable injection will be sweet, lean on the bottom and rich on top.
    Klotz used to be a secret of snowmobile country when I first started mixing fuel. Great stuff, I mix their SuperTech at 40:1
    :cheers:
  14. ohmygewd Husqvarna
    Melbourne, Australia
    Aprilia RSV1000
    You run a certain premix or the type of riding you are doing, tight slow single tracks run 40/50:1 and above as you are more prone to fouling due to low speed riding with a rich oil mix, ride fast open trails and desert then run at 30-40:1 where your are riding majority at 1/2 throttle and above and the motor requires more lubrication - essentially if you ride on the stops then run a rich mixture.
    With the quality of even the cheapest synthetic premixes these days, running at a baseline of 40 or 50:1 is the norm.
  15. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    More oil=more power over the rpm range. That should stir the pot
    NCSteve and steadydirt like this.
  16. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    32:1 everywhere! :)
  17. 454x Husqvarna
    Dunnigan,Ca.
    2012 CR165 w/36mm lectron.
    64:1 every where. 2 ounces per gallon is easy to remember.
  18. steadydirt Husqvarna
    Ontario
  19. steadydirt Husqvarna
    Ontario
    -to a point- 18/1 provides max horsepower-best ring seal-
    it is significant if you need every pony
  20. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    18:1 the greenies would have kittens!
    Ya rite 454x being easy to remember helps. Bring back the old days of 20:1 castrol super TT. Jus pour a whole 1L bottle in 20L jerry can
    NCSteve likes this.
