250-500cc Wr 300 Generator Or Alternator
Discussion in '2 Stroke' started by Rob578, Aug 16, 2011.
  1. Rob578 Husqvarna
    Atlanta GA was CA
    Beta 300RR Beta 500RS TE 630
    Honda 919 sold FJR1300 sold
    I always assumed the WR's had a DC generator but looking at the shop manual they seem to use the terms interchangeably. Page m.9 says use a VAC and the voltage should read >20-50< volts. The only reason I ask is that I want to order a lighting kit and don't know if I need the regulator/rectifier or can just use the stock regulator.
  2. PC. Husqvarna
    Beaverton, OR
    CR165 & CR144
    KTM500
    I needed a recitifer on my 09, but the bikes with the Ducati ignition may be different.
  3. Rob578 Husqvarna
    Atlanta GA was CA
    Mine's an '09 I'll break out the voltmeter this weekend
  4. motomaniac Husqvarna
    Kamloops BC Canada
    2010 WR300
    2009 RMZ450 2005YZ250 2001 EXC300
    It AC voltage. Just built some some high powered LED lighting for my 2010.
  5. MR54L Husqvarna
    QLD AUSTRALIA
    WR250
    I now run LED tail light & turn signals, only changed flash can. All appear to be working fine
