250-500cc WR 300 idle adjustment
Discussion in '2 Stroke' started by ks9mm, Apr 10, 2014.
  1. ks9mm Husqvarna
    NJ
    2015 TE 125
    2014 Beta 300RR
    Hi all,
    Sorry for stupid question, but how do you adjust idle on mukini? Is it that Philips screw closer to air box? Should the nut be loosened prior to messing with it?
    I have recluse, so good idle is super important and mine seems rather high. And it seems to take some time for revs to drop down for idle to settle. Other than that, bike runs fine and starts ok.
    Thanks!
  2. ks9mm Husqvarna
    NJ
    2015 TE 125
    2014 Beta 300RR
    One more thing, previous owner told me that bike was jeted for VP C 9 gas. I run regular 93 pump.
  3. PowerKord Husqvarna
    Notheast Ohio
    2008 WR 250 Sold
    2014 Sherco SE-R 250
    Yes, you've got the right idea. Loosen the jam nut and then adjust with a Philips. FYI, you can eliminate that dopey set up and install a new idle screw from Stealth racing. Then you can adjust the idle with a gloved hand, no tools required.
  4. Kyle Tarry Husqvarna
    Portland, OR
    2012 WR 300, 2006 TE 610
    Ducati Monster S2R 800
    Given the difference in fuel, I'd pull the carb (or just rotate it in the boot) and see what jets are in there. If they are whacky, we can offer some recommendations.
  5. GhostRider32 Husqvarna
    14 WR300
    03 KX250
    I tried to find the stealth racing website but only found car and bicycle sites. Do you have a link?
  6. ks9mm Husqvarna
    NJ
    2015 TE 125
    2014 Beta 300RR
    by
    whacky you mean not standard? and we are interested in Pilot jet only, right?
    goal is to have bike settle in to low stable idle quick.
  7. Kyle Tarry Husqvarna
    Portland, OR
    Ebay Store: http://www.ebay.com/itm/Idle-Screw-KTM-HUSQVARNA-MIKUNI-TMX-Two-Stroke-Carbs-/380474052129
    Cafe Husky Threads: http://www.cafehusky.com/threads/stealth-racing-idle-screw.7470/
    http://www.cafehusky.com/threads/husqvarna-wr250-mikuni-tmx-carb-idle-screw.27408/
    FYI, these all turn up on the first page of a google search for "Stealth Racing Mikuni Idle Screw". ;)
    If the bike is jetted for race fuel, it's possible that all the jets (including needle and clip) are different than what you would run on pump gas. For the long term health of your motor, you probably ought to check them all.
  8. ks9mm Husqvarna
    NJ
    2015 TE 125
    2014 Beta 300RR
    You are right. It's simple enough to do.
    I am a bit cautious as bike runs and starts fine now :) and has very mellow response, which is good for newbie like me.
    Original owner did give me few spare jets
