250-500cc WR 300 rattle noise
Discussion in '2 Stroke' started by hogwackr, May 14, 2011.
  1. hogwackr Husqvarna
    pennsylvania
    18 TE 250
    13 HD Street Glide
    Does anyone notice a rattle noise on there WR? It almost sounds like someone is banging rocks together. It only seems to happen in the mid range. I don't hear it down low or in the upper rpm range. I noticed this noise from day 1. I can't seem to duplicate it long enough to try to figure out where it's coming from. Any advise?
  2. hogwackr Husqvarna
    pennsylvania
    18 TE 250
    13 HD Street Glide
    I'm running 93 octane and Klotz Super Techniplate @ 40:1. Could it be detonation?
  3. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    Does it make it at steady throttle? On acceleration? Deceleration? Maybe the powervalve linkage is making that noise.
  4. hogwackr Husqvarna
    pennsylvania
    18 TE 250
    13 HD Street Glide
    never on decel, maybe a slight sign on accel. Loudest at steady mid rpm throttle. It will come and go, I can't seem to make it continuous. It never does it on hard throttle only with moderate throttle. I would think detonation would happen across the rev range but I'm not sure. Thanks for the reply!
  5. windsurf Husqvarna
    queesland
    I don't know if you rotated the kickstart round one spline? I have on mine and when you aren't riding there looks to be sufficient clearance between the pipe and kickstart. When I first rode the bike at mid throttle there was a loud metalic vibration. It was infact the kickstart vibrating against the pipe and only doing at certain throttle openings.
  6. hogwackr Husqvarna
    pennsylvania
    18 TE 250
    13 HD Street Glide
    I have not moved the kickstart. I will however check it next ride and see if that is it. Thanks.
  7. hogwackr Husqvarna
    pennsylvania
    18 TE 250
    13 HD Street Glide
    Well, I rode it today and the kickstart has nothing to do with my noise. I pulled the plug and it's a nice shade of brown. I'm convinced it's inside the engine, I just don't what the cause is......[IMG]
  8. lankydoug Husqvarna
    MO
    WR
    TM 300en
    The power valve on a GasGas can make a rattle especially when it's lugged along in 3rd gear. I'm not sure if a husky can do the same thing, when my GasGas does it it almost sounds like the chain is slapping something. I've never heard my Husky do it though.
  9. MOTORHEAD Husqvarna
    Mount Vernon, Indiana
    2014 YAMAHA YZ250
    Sounds like detonation to me. I'd say you're on the road, holding the throttle at one spot and letting the bike go through the rev range in that position ?
  10. hogwackr Husqvarna
    pennsylvania
    18 TE 250
    13 HD Street Glide
    It is very noticeable while crusing at a consistant speed. It will do it other times but not nearly as frequent. What do I need to do to eliminate it? I never ran into this before.
  11. lankydoug Husqvarna
    MO
    WR
    TM 300en
    If you think it's detonation try higher octane fuel and/or jet the according circuit richer. If it does it at the same throttle position, say for example just off idle then go richer on the pilot or even try adjusting the air screw.
  12. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    You'll simply have to add fuel at that throttle opening. I'd guess you needle diameter is too big, or pilot is too small. Might just try moving the needle clip down one and see if it helps.
  13. hogwackr Husqvarna
    pennsylvania
    18 TE 250
    13 HD Street Glide
    Thanks for the help guys! I'll post back when I get a chance to tear the carb off and see whats going on.
  14. buzuki Husqvarna
    sydney, australia
    WR300 '09
    KDX200,KX125,CR250,50cc quad,
    hmm mine makes a screech under accel, only happened last ride, i think its clutch noise.
    yeah id check your jetting first, maybe wrong in your mid range.
  15. hogwackr Husqvarna
    pennsylvania
    18 TE 250
    13 HD Street Glide
    I'm going to start by moving the needle up a notch and go from there. I talked to my dealer and he said my condition may have something to do with the new ignition. They have been using the same jetting that they used with the old ignition. Maybe the timing is different with the electronic ign?
  16. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    Yes, it might have something to do with the new ignitions. Do you have taller gearing for street use?
  17. PC. Husqvarna
    Beaverton, OR
    CR165 & CR144
    KTM500
    Check timing too. My yami came advanced 1.5deg from the factory and I could never get rid of the ping until fixing that.
    Sure ran hard though!
  18. hogwackr Husqvarna
    pennsylvania
    18 TE 250
    13 HD Street Glide
    Running stock 13/48 gearing. It makes the same noises in the dirt but mostly when maintaining speed. It won't do it when wicking the throttle. I really only do small sections of road use. Mostly connecting trails. I think you guys are on the right track, Prob. just leaning out at consistant throttle.
  19. lankydoug Husqvarna
    MO
    WR
    TM 300en
    Husky recommends 95 octane.
  20. hogwackr Husqvarna
    pennsylvania
    18 TE 250
    13 HD Street Glide
    I will try Maxima octane boost and report back. Should I also raise the needle or try the boost and see what happens?
