125-200cc wr 300 rear brake issues! Help
Discussion in '2 Stroke' started by David Johnson, Sep 24, 2012.
  1. David Johnson Husqvarna
    Lyndon KS USA
    2011 WR 300
    1992 KTM EXC 250
    Been riding 2 hr. hare scrambles and lately have had rear brake fade issues. Usually about 45 minutes into race especially when riding hard it seems rear brake fluid boils and I loose my rear brake. Can ride for a few minutes not so hard and can get brake pedal back. Lately I seem to have problem dragging rear brake, that and Im getting faster. Any suggestions on vented rotor or modification to rear brake system, or do I need to change my riding style? Current rear brake is stock with solid rotor. Note: Tried DOT 5 fluid and same result.
  2. Gotlabs Husqvarna
    Branchville, SC
    12 CR144 X 2!
    DO NOT USE DOT 5 brake fluid, it will eat the seals/orings. Use only 4 or 5.1. I've never had a problem with mine overheating in 1.5 yrs of racing HS and enduros. I run my lever low with about .25" of free play.
    READ THIS
  3. MOTORHEAD Husqvarna
    Mount Vernon, Indiana
    2014 YAMAHA YZ250
    I use Motul 660 brake fluid and EBC carbon X pads. My rotor and pads look like they have been in a fire after a race, but I rarely get brake fade.
  4. ajaxauto Husqvarna
    Here is what I tried first and it helped rear vented rotor off a older Cr 250 from Halls with motol brake fluid
    BUT if you want to get the best here is what I did Had Ty at Zip Ty Racing make a bigger caliper braket
    went with a vented rotor off a TE style bike Mounted it solid not free floatting any more
    Results great brakes no problem.So why does Husky use a bigger rear brake on ALL there bikes from 125 to 511 except the WR 250/300 gets a small rear brake
    Maybe next year we will get a updated 250/300 2 stroke
  5. David Johnson Husqvarna
    Lyndon KS USA
    2011 WR 300
    1992 KTM EXC 250
    oops! goes to show how much I know. Good info. Thanks.
  6. street2dirt Husqvarna
    World's Most Famous Beach
    12 TXC310, WR300, 85 125WR, 82 175XC
    BMW G650X
    +1 on the Motul 600, I've not had rear brake problems but my pumpkin ridin' brake draggin' friends have had to use it to cure theirs.....
  7. David Johnson Husqvarna
    Lyndon KS USA
    2011 WR 300
    1992 KTM EXC 250
    Thanks to all for the info.
