250-500cc Wr 300 Rekluse Clutch Left Hand Rear Brake.
Discussion in '2 Stroke' started by Haggis78, Jan 28, 2012.
  1. Haggis78 Husqvarna
    Perth Australia
    WR 300 2009
    Triumph 1050 Speed Triple 2006
    Hi,
    I have installed a left hand rear brake on my 2009 WR300. I am using magura clutch lever and want to use the hot start as a secondary clutch.
    My problem is that the clutch cable diameter is too big for the hot start lever.
    My question is has anyone set one up?
    Did they have to get a sustom cable made up?
    Can you actually get a cable made up?
    I have spoken to all of the local bike shops and have no luck.
  2. firecrotch Husqvarna
    north bend, wa
    2009 wr300
    2007 ktm 950SM
  3. Steve-oh Husqvarna
    Lethbridge, Alberta
    2010 WR 300
    04RM250, 05XR100,07PW80,41 Harley
    Haggis78 did you figure out how to use the hot start lever as your secondary clutch lever? I too have a rekluse in my 300 and have now ordered a lhrb set up from Motosportz. The clutch pull is so easy with the rekluse installed I know the short hot start lever will work fine for blipping the clutch when needed to. My plan was to use the lever but now I might just cut back the old clutch lever and put a little bend at the tip so my index finger can get a good bite on it.
    Thanks in advance for any advice given.
    Steve
  4. Xcuvator Husqvarna
    Scholls Oregon
    yes
    Rekluse makes a "hot start like" clutch lever that goes on the top of the MC that will fit your cable.
  5. Steve-oh Husqvarna
    Lethbridge, Alberta
    2010 WR 300
    Thanks Xcuvator, I'll check it out.
  6. Haggis78 Husqvarna
    Perth Australia
    WR 300 2009
    Hey Guys,
    I have set up the LHRB with a secondary clutch.
    I bought the Magura clutch lever and hot start from 100% mx. About $250.
    It is the 10.5 and uses brake fluid not mineral.
    I drilled out and tapped a thread in the hot start for the clutch cable.
    Cable is slightly too long but I put a small cable tie around where it goes into the housing. Its enough to take up the 10 mm slack.
    I got a braided line made up from Hel in Queensland $90 including postage.
    Everything worked out well and the rear brake is awsome.
