250-500cc wr 360 2002 feather light venhill clutch cable
Discussion in '2 Stroke' started by juicypips, Jun 7, 2013.
  1. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    right i purchased a featherlight cable from venhill cus im in the uk and no one stocks motion pro terminators here...
    the clutch end fitting is a straight connection not a 90 bend like stock, shall i unsolder the nipple rethread in my existing cable bend or shall i leave it rubbing against the coolant hose???
    input please
    p.s. any one used motion pro raptor?
    or whirtz racing easy pull?
  2. Crocus Paper Husqvarna
    UK
    WR250
    Scorpa 300 Aprilia Dorsoduro 750
    Maybe speak to Venhill to see if you've got the right one. They can also make cables to your requirements.
  3. justpinit Husqvarna
    Maryland
    2012 wr 300
    93 kx 125 with a kdx 200 engine.
    Bought A venhill for my 12 wr 300, they made it 4" shorter for me! Took two weeks to get it to me in maryland.
  4. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    contacted them an they mentiond production costs and to fit it and see if it works, it does but its rubbing the coolant hose i will resolder the nip on after ive threaded it through the existing right angle.
    they are very helpful to and quick to post and respond to any questions A* will use again
  5. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    I was buying a Terminator cable for my 1999 360 and the Motion Pro book showed the one with the straight end but as you stated it would rub against the hose so I opted for an earlier cable from the catalog and voila the end looked like my original
    so look for an earlier cable the fit fine
    juicypips likes this.
