250-500cc WR 360 case split
Discussion in '2 Stroke' started by Torben45, Mar 3, 2017.
  1. Torben45 Husqvarna
    1986 Husqvarna 510 TE
    Ossa TR 300i, Aermacchi 350,
    Hi all,
    I'm doing a new con rod, bearings, top end etc on my 360 motor going into a 2000 WR 250. I'm having an issue splitting the case though. I'm using a tusk type puller and when I pull it apart it splits about 1/4" then the back starts to close back up. I closed it again then re opened it and put a plastic wedge in back and continued but then it started closing by the kick start shaft and not opening anymore. . I'm wondering if anyone has experienced this and what the solution/problem was?
    Thanks! Frustrated
  2. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Have you removed the kickstart lever? If so with a wooden block hit where the nut goes when you've got pressure on the cases
    My guess is your kick shaft needle rollers are binding on the kick shaft just help it along with a little love tap.
    You've got the stator and everything stripped?,pictures really say a thousand words.
  3. Torben45 Husqvarna
    Yes everything else is stripped down. I've tried tapping on the kick start shaft...whatever is stuck is solid. I've done quite a few case splits and this one is an odd one. Didn't know if this case specific has issues when pulling? I'll take some pictures today as I had to step away before throwing it across shop....
    2premo likes this.
  4. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    throwing things offers temporary satisfaction and long term grief :D
    Torben45 likes this.
  5. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Pictures. Pictures. Pictures. How stripped?
    Is the gear on the ratchet mechanism removed as that could be caught.
    Seriously is a whole guessing game wich was fine for the first ten guys but I'm getting tired of asking same questions.
  6. Torben45 Husqvarna
    Lol....yes I got through it today. The kickstart shaft and bearing it rides on we're stuck quite a bit. Got it apart and used the parts from my WR 250 and good to go now. The whole 360 motor is now new. Here is a pic of the case opened. You can see the wear on the kickstart shaft. Really appreciate you guys chiming in. 13EBAFD9-F0E9-4448-964D-F8D302D95B9C.JPG
    ohmygewd and juicypips like this.
  7. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Remember the shim orders on the gear clusters.
    That's a tidy bottom end.
    Pleased someone knew what they're on about.
  8. Torben45 Husqvarna
    I agree. The shims were pretty straightforward and I had the parts breakdown to look at. What was really fun was the loose needle bearings under cog 2. Lol. Who does that anyways it's back together and going to heat cycle today and go ride a bit
    juicypips and Dauer like this.
  9. Torben45 Husqvarna
    Thanks juicy for giving me opinions on the 360 motor too....much appreciated. I am dialing it in. I did find out that a 250 clutch actuator arm is actually longer than the 360 arm and used it instead and now clutch pull is great. Don't know if it's been talked about here? Also is there anyone who knows the motor #'s for me to find out what year the motor is? I was told it was a 2002 but has a head with no stay on it?
    I'll post these pics if it helps..... I painted the cyl head and side covers so I can't go by that....they were stripped when I got it.
    juicypips and justintendo like this.
  10. Torben45 Husqvarna
  11. 2premo Husqvarna
    Northern NV
    look at the right inner case tag for the year
    the head is a 92 as it was the only one without the bosses, most likely must have been a top end failure that caused them to replace the head
  12. rancher1 Husqvarna
    WA
    Can you show the front of the cylinder, the pipe mounting was different in 92, so that would be a tell.
    Torben45 and 2premo like this.
  13. 2premo Husqvarna
    Northern NV
    looking at his pipe, pretty sure FMF did not make a Gnarly for the 92 cylinder
  14. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Nice looking bike, how she's as good to ride as she looks.
    I would be keeping an eye out for a head with a stay.
    It will probably be fine.
    No I didn't realise the clutch rod was longer on a250 I cut and shut mine 5mm longer.
    Find the biggest factor in clutch pull is leave adjustment and having that clutch arm not pulling over90.
    Another member told me that many moons ago.
  15. Torben45 Husqvarna
    The numbers are Husqvarna A2 can't remember the rest but just serial # . The cylinder the pipe goes "in" and not around exhaust spigot.
  16. Torben45 Husqvarna
    It's 3h1 A2 0012
  17. Torben45 Husqvarna
    Thanks for the compliment. I have been building it up for some of the enduro series in CO and some of the HS events. I'm going against all modern in my class so I wanted to build the bike the best I could. I LOVE the motor on this. With the FBF fork and Ohlins shock...the suspension is easily as good of better than the newest stuff. Very controlled suspension and the 50mm fork is night and day stiffer in deflection and stays up in stroke better. It's riding very good so far but yesterday was a 1/4 throttle pretty much kind of day. All new motor.
    The frame is the 2000 WR so it has the head stay mounts so I will look for one on flea bay or something. Need to stop spending on it for a while as wife is asking how much I've spent....haha.
    juicypips likes this.
  18. Torben45 Husqvarna
    Oh shoot...almost forgot. does anyone have a pipe guard for the gnarly? It is Colorado and in the past I usually go through 2 pipes a season.
  19. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Not gota clue on the pipe guard, think Hyde Do one for the 300 that may fit but I wouldn't quote me on that.
    I've not bought one but if they do please point me in the right direction.
    As for spending onthe bike can you put a price on awesome?
  20. Torben45 Husqvarna
    No you can't...and it's a great bike. Pretty much all new.....now I'm developing a leak in the old intake manifold...one of the few parts I didn't change. Lol. Now I have to find one of those. If I can't find a pipe guard I may make one out of carbon fiber.
