250-500cc Wr 360 squish help
Discussion in '2 Stroke' started by juicypips, Nov 8, 2014.
  1. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Right im in need of guidance once again, unusual i know lol
    Put 93 360 cylinder on the last month clocked 17 hours ride thought wheres my beast from before gone? So i measured me squish its at..... 2.73mm wow huge seeing as i thought it was supposed to be close to 1mm or 50 thou.
    So i need to cut a whopping 1.7mm ignore the three for safety?
    So my head before the band measures .83mm
    And the deep groove in cylinder measures 2.09mm
    I dont fancy reshaping combustion area so i plan to take .7mm from head
    And a 1mm from top of cylinder re machine gasket rings, will this be acceptable?
    P.s. My base gasket is .03 thinnest i could get.
    Help me help me help me.
    Cheers guys n gals
  2. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    when you first assembled it did you check the squish
  3. wallybean Mini-Sponsor
    Montana
    Your 360 is whole different animal. I would do some research before you cut that much off your head deck.
  4. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    im not sure how you are measuring squish but that seems way off. what piston are you using? do you have a dial indicator to check it per shop manual? i had to use two thin base gaskets to get mine correct but its right on per book..i have a wossner in my 95. once i adjusted my pv it has a great spread of power, and pulls hard on the top end hit.
  5. justintendo klotz super techniplate junkie
  6. 2premo Husqvarna
    Northern NV
  7. Petar Husqvarna
    Pernik, Bulgaria
    Wr 300 94
    If you dont have dial gauge, you can also use solder squish band check to be sure.
  8. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    No didnt check upon first assembly, just made sure there was no interferance as i was doing a rally on the weekend.
    i used solder and am measuring the distance from piston corner to the corner of squish band, then im using digital calipers to read the solder.
    2.6mm is huge tho.
    Will have to get a dial indicator but couldnt see anything wrong with solder method.
    Thanks for the pic is that for all years of 360 as the 93's wilder porting than the 2000's?
    Its a wossner piston but the heads off a different bike.
    I know if i go too small a clearance i risk holing my piston but ive got a lectron set up dam near perfect and am aiming for a bit more hit.
    Basically shes not lofting the front like she used to an i miss it :,(
    Still same gearing pv ive played with no avail
    Carb made her run much nicer
    Cylinder made top end wake up
    Gnarly made more power
    Boycesen reeds didnt notice difference... So i thought squish
  9. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Thats why i ask you... Reading the multi lingual manual is hard work.
    Just being lazy and more opinions the better dont want to junk a perfectly good engine.
    Oh i got the 1mm clearance as a guide from rd 350 settings i asumed most 350's would be around that area.
  10. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Dale Alexander also explains it well in his RD tuning articles in the ACTSO archives. Basically, any charge trapped in the squish area (between the piston and squish area of the head) does not burn, due to localised cooling from the heads material. So what you want to do is to keep that amount of unburned, thus unused (meaning it's just along for the ride and does not make any power) charge minimised. You get the gap (squish clearance) reduced to a safe amount so the piston does not whack into the head at max rpm. That gap is usually in the .030-.040" range. This squeezes all that once unburned(when the gap was.060") charge into the bowl proper where it gets burned with the rest of the mixture and helps create power.
    This was one of the articles i got information from.
    ray_ray likes this.
  11. 2premo Husqvarna
    Northern NV
    that's not really appropriate as the RD350 was a twin so you have a 175 cylinder that also happens to be air cooled
  12. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    See thats why i asked! Lol whats your squish set at?
  13. 2premo Husqvarna
    Northern NV
    funny but out of all the 360's i have never had a head off any of them
    they run strong and long, this year i will pull my 93 down as it has the most hours on it and it is not running as sweet as it used to
    but 10 years who's to complain ;)
  14. justintendo klotz super techniplate junkie
    not sure if the different porting on later years is going to change anything. the pic is from my 95 manual.
  15. Mobil1 Husqvarna
    Wr 250 2003
    2,6mm is alot, but will have it reasons from factory i guess.
    For the 2t race engines i have made and seen made snd learned from very experienced people is keep the squish tight for bottom end power. Especially if you make the exhaust higher as you will lose compression by doing this.
    Best is to calculate the compression ratio to stay safe. Or just dont touch it :-)
  16. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    10years??? Not even a set of rings? Piston conrod? Find that very hard to believe do you actually ride it?
    2premo likes this.
  17. duggoey Husqvarna
    NSW, Australia
    2010 TE 310
    KTM 690, Yamaha WR200, FGS650(800cc)
    My mates 1998 Yamaha WR 200 is on the original piston and rings. It has been ridden hard since 98. Mine on the other hand was completely screwed, had to rebuild it bottom up.
    2premo and juicypips like this.
  18. justintendo klotz super techniplate junkie
    my 88 250 is on the stock top end, i bought the bike as nos in 98. it has seen quite a bit of service, and still hits 212 psi on my gauge..im probably going to replace the piston just because of fatigue
  19. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Nuts pure nuts i think im getting good mileage from a years worth of hack about... Mind you im the type of bloke that out of 1000 perfect things i would pick the one thats problematic.. Lol
    Im gunna tamper with the squish clearance set it to 55 thou whats the worst that can happen? I hole a piston grenade the bottom end and have £300-400 rebuild... Nothing ventured an all that.
    I assume the tolerances are so huge due to vairants in rods pistons cylnders n head machining getting it exact and spot on in mass production is costly and time consuming.
    Will give it a bash an keep you posted.
    Thanks for your input guys n gals ;)
  20. 2premo Husqvarna
    Northern NV
    ride the piss out of it but always 3 bikes in the stable so its not the only one seeing my abuse :D
