Am thinking I need a steering stabilizer .... What is available that fits an '01 WR360? I've seen A Scott's mount for the fender, if I go this route, what model stabilizer would fit? Thx, Kirk
I have a 00'. I'm running an original GPR V1 unit on a BRP triple clamp with the old school weld-on stem. It all came from GPR as a package deal "back in the day". Both BRP and GPR don't appear to make my setup available anymore. You will most like have to buy an after market triple clamp to make this happen as I recall the OE triple clamp bar mounts are too close together for mounting a stabilizer. You should call the guys at BRP. I'll bet they can work out a triple clamp solution along with a Scott Performance unit.
I stand corrected. Scott's Performance actually does have a mount setup without the need for an aftermarket triple clamp. Hmmm....... Scott's unit are much smaller than a GPR and that's how they get away with it. That's the route I would go for sure.
if theyre the same triples as newer models I got an underbar set up that will fit. pm me if interested mate
