250-500cc wr 360 water pump issue
Discussion in '2 Stroke' started by Yoavv, May 13, 2011.
  1. Yoavv Husqvarna
    Hi.
    I'm having problems with my wr360 93'.
    I have cooling water coming into the transmission oil, I figured that most commonly they coming from the water pump o-ring that was damage.
    i couldn't find any workshop manual.
    My question is how to take out the rotor of the water pump?
    Thanks
  2. colemanapp Husqvarna
    St. Louis, MO
    Grab the rotor with some pliers and turn clockwise to remove.
  3. ohmygewd Husqvarna
    Melbourne, Australia
    Aprilia RSV1000
    I hope it's only the water pump o ring as the worst is the the crankcase seal has failed which you may need to replace it.
  4. Yoavv Husqvarna
    Thanks for the help.
    It is the worst.. but its not so bad.
    Now waiting for the parts,I'm about to replace the o-ring, spacer and the Oil returns. Hopefully It will solve the problem..
    I'll keep you posted.
