125-200cc WR g/box into a CR125?
Discussion in '2 Stroke' started by Parfo79, Nov 23, 2010.
  1. Parfo79 Husqvarna
    S Wales, UK
    '98/'05 CR125, '00 CR250
    many...
    Ive lost a couple of teeth off my '98 cr125's box. Ive managed to find a box locally but its for a WR125 from the same year.Will it fit? The taller gearing will suit me better so im really hoping it does.
  2. ScottyR Husqvarna
    Mitchell, ON
    I dont know much about the older 125s, but the newer model CRs and WRs have the same tranny.
  3. wallybean Mini-Sponsor
    Montana
    The 98's had different trannies between the cr and wr. I believe that is true through 02. The CR tranny is the same for the current 125's. The WR tranny had different gears throughout except for 6th. So 1st in the wr is lower than 1st in the cr. It takes one tooth less on the CS to make the CR 1st equal the WR 1st. Another way to look at it is that you could run 14x52 gearing on the wr and still have the same low 1st that you have with the 13x52 and the cr tranny that most guys like.
