125-200cc WR Power Valve Gear
Discussion in '2 Stroke' started by 3chris333, Feb 24, 2016.
  1. 3chris333 Husqvarna
    WR 125
    Suzuki GSX-R 600
    Hi All,
    When I got my WR it was missing the gear that runs the power valve...was just completely missing.
    I have purchased the bit and it fits perfectly but it makes the bike almost impossible to kick over and makes a noise like it is fouling on something even though there appears to be nothing in the way.
    The system was all cleaned and is moving freely
    Does that sound like a setup issue or am I missing something?
  2. freezerGeezer Husqvarna
    Norfolk, UK
    2004 CR 165
    Hi,
    I had a similar problem a while back:
    http://www.cafehusky.com/threads/1998-cr-125-lacking-of-power.43816/#post-425545
    You need to make sure 100% that the gear on the governor is meshing with the gear inside when assembling.
    Leave the PV linkage cover off and check to make sure its not trying to operate the linkage when you try to kick it over, is the replacement second hand? It could be faulty and permanently engaged?
    Also need to get the positioning right, ie the linkage arm has the be at the right angle as you insert the governor assembly, this allows the small gear on the on the linkage shaft (at top of the opening) to mesh into the slots/grooves on the governor.
    Its worth leaving the PV linkage cover off for a test ride so you can easily adjust the setting.
    Hope this helps:thumbsup:
    lankydoug likes this.
  3. freezerGeezer Husqvarna
    Norfolk, UK
    2004 CR 165
  4. 3chris333 Husqvarna
    WR 125
    Suzuki GSX-R 600
    Brilliant, will have a look later...fingers crossed!
