250-500cc WR Sachs Shock Rebound Adjustment
Discussion in '2 Stroke' started by webski, Sep 11, 2013.
  1. webski Husqvarna
    Kansas
    83WR250-09TXC450-13WR250-09WR165
    KTM 200 XC - Honda XR 440
    Where is the rebound adjuster on this shock? It appears to only have the high and low speed compression adjuster and no rebound adjuster. Is this correct?
  2. JRod4928 Husqvarna
    Pittsburgh, PA
    2012 CR165
  3. Eaglefreek Husqvarna
    Fayetteville,TN
    11 WR300
    You have to compress the suspension a bit to see it. It's kind of in a bad spot. I had a tough time finding it myself.
  4. Motosportz CH Sponsor
    this
  5. kx3089 Husqvarna
    western pa
    wr250
  6. Rama Husqvarna
    wr 250 2012- sm 125 2t 2010
    This is one major flaw! how do you compress it on the trail etc? or even when its on kick stand. its like a 2 man job it seems! any detailed tips or tricks?
  7. kx3089 Husqvarna
    western pa
    wr250
    You don't need to compress much.Stand on the clutch side and lay over the seat and adjust.If you compress to much the linkage gets in the way again.Pain in the ass.
  8. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    the showa on my 95 is like this as well. its actually pretty easy once you have done it..i use a long skinny flathead screw driver and just compress it slightly..
  9. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    All I have to do to reach it on any of my bikes, is stand the machine up. The proper amount of free sag will bring the adjuster into view. I don't think that I've had to add any more sag than that to get to the adjuster.
