All 2st WR Scotts damper mount options
Discussion in '2 Stroke' started by Tommy V, Feb 23, 2016.
  1. Tommy V Husqvarna
    2002 WB165
    GasGas TXT280 trials
    Hey, looking for mounting options for a Scotts steering damper for my 2014 WR 300
    Would like to retain oem top clamp and just get new bar mounts, prefer top mount as I don't want to raise the bars at all
    What options do I have?
    Scotts site only showing SUB mount
  2. Claybilly17 Husqvarna
    Ohio
    2000 WR250
    2009 KTM 450 SXF
  3. Claybilly17 Husqvarna
    Ohio
    2000 WR250
    2009 KTM 450 SXF
    Just found this too
  4. Tommy V Husqvarna
    2002 WB165
    Thanks, pretty sure the KTM bolt pattern is different. My buddy has a SUB mount that I'm going to try. Hopefully raising the bars won't affect handling too badly. I was running taller bars for a while and I liked them for certain trails but overall the bike wouldn't turn as well. Another friend of mine had the Ohlins damper on his TE250 and it didn't raise the bars at all but it will def make your wallet thinner.
  5. hesutton Husqvarna
    Kentucky
    2014 WR300 (SOLD)
    2021 Sherco 300SE 2002 Honda CRF450
    How about Zip Ty's removable bar mount/stabilizer mount kit on a WR250/300?
    http://www.ziptyracing.com/removable-bar-mount-stabilizer-mount-kit/
    If it will work on a WR300, it'd be a way to get a Scott's stabilizer mounted without having to use a BRP sub mount. Again, keeping the bars at the stock height is what I'm looking for as well.
    Heath
  6. hesutton Husqvarna
    Kentucky
    2014 WR300 (SOLD)
    Never mind on the above mount.
    Called Zip Ty yesterday. It will only fit Yamaha's. Won't work on our Italian WR's.
    I don't want to sub mount a Scotts either. Don't like the idea of raising the bar height another 2-3 inches or having to swab to a super low bar bend to compensate.
    If you find a solution.... please share.
    Heath
  7. BenM Husqvarna
    CT
    TE300 WR360 WR125 CR250 WXE250 TE610
    950ADV, 250XC, IT465,
    Funny, I'm trying to achieve the exact opposite on my '02 CR250. BRP/Scott's offers a weld on tower & standard top clamp mounted stabilizer for the older models (99-05). However, I run an HDB top triple clamp & guards and need the sub mounted version so everything can jive.
    Just an FYI, I think the stock bar clamp height is around 1.3-1.5", so the the sub mount will only raise it 1.0-1.2"
    You may want to call BRP or Scott's to see if you get something to work for your application. I was on the phone with BRP earlier today and they were very helpful.
