125-200cc Wr - Spark Advance With Cdi
Discussion in '2 Stroke' started by caveira, Aug 15, 2021.
  1. caveira Husqvarna
    Brasil
    good night,
    I installed on my motorcycle (WR 125 / 2006) the CDI of the WR 360 / 2002
    at first I left it a little behind in relation to the original.
    I'm having difficulty getting the ignition timing right, because the bike ends up drowning and then the difficulty in starting.
    what is the correct position?
  2. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    the ignition curve is electronically set in the ignition, you would be wise to find a 125 ignition as it has the correct curve
  3. caveira Husqvarna
    Brasil
    burned the coil and I couldn't find another one to replace it.the original system on this bike doesn't have a CDI, it's the analog system.
    I had the 360's cdi + coil left over, so I wanted to take advantage of it.
  4. caveira Husqvarna
    Brasil
