125-200cc Wr125/150/165 Clutch Cover Bolt Hole Stripped, Help!
Discussion in '2 Stroke' started by macd, Mar 21, 2019.
  1. macd Husqvarna
    New York, NY
    wr125/150
    Hi there! I just got a hand-me-down WR165 that needs some work.
    It's leaking a little oil from the clutch cover, and I discovered that the right lower bolt hole is stripped. I can screw the bolt in, but it doesn't get tight, and if I go too far it pops and feels loose again.
    Is there a way to fix the threads in the hole without breaking?
    Thanks!
    MacD
  2. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    You can use an insert kit. 6 mm inserts, drill, tap and insert tool can usually be found at any auto parts store.
    lankydoug likes this.
  3. lankydoug Husqvarna
    MO
    WR
    TM 300en
