125-200cc wr125 frame
Discussion in '2 Stroke' started by water racer, Mar 15, 2010.
  1. water racer Husqvarna
    http://www.knoxenduro.com Knoxville, Tennessee
    2013 Beta 250RR
    2009 Husqvarna WR125 1997 Fantic
    I am curious about a few things on the 09 wr125, I have heard conflicting info.
    The 09 supposedly has a new frame, is it the same as the 2010 tc250, and is it different from a 2009 txc 250.
    Also, is the cylinder new starting new in 09, if so what is different. I realize it has the 50mm forks and a newer Mikuni carb.
    I am loving my bike, just wandering what makes it so good.
    Thanks, GP
  2. wallybean Mini-Sponsor
    Montana
    Essentially the same frame as the 2010 TXC/TE/TC 250. The 08 CR125 got a new cylinder, power valves, and reed valve. In 09 both the CR and WR got the new parts. They changed to the TMXX carb in 09 from the TMX in 08 and before.
    Walt
  3. water racer Husqvarna
    2013 Beta 250RR
    Thanks Walt,
    What were the differences in the cr and wr powervalves that got changed out. That had already been done when I got my bike and I did not get the old parts.
    GP
  4. Motosportz CH Sponsor
    They had a bad batch of powervelves that were cut wrong from their suppliers. That was rectified. The 2010 TXC250 and 90-10 WR125 have a similar frame but the bottom part is completely different (I own both bikes). This is the based on the third generation of the semi perimeter frame they came out with in 08. LOVE this frame. :thumbsup: 09 and up WR125's have a slightly different transfer port setup than 08 and older.
  5. water racer Husqvarna
    2013 Beta 250RR
    That sounds good, if I decide to add a tc/tcx250 in the future, it should make a good mate to my 09 125, and I will be able to switch back and forth with relative ease.
    Best of both worlds!
    GP
