125-200cc wr144 vs cr 165
Discussion in '2 Stroke' started by bsh7680, Jan 21, 2013.
  1. bsh7680 Husqvarna
    Cookeville TN
    12 CR 150
    04 PW 50, 08 KTM 50 JR Pro
    I am coming off an 09 wr 300 and think that I am going with a smaller bike. I have found a wr 144 and a cr 165 that I am trying to choose from. I only ride woods and it is pretty hilly here in TN. Any comments about the differences would be appreciated to help with the decision.
    Thanks
  2. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    My WR 144 ended up a fantastic bike ! did just about every thing I asked from it, tried the cr and ktm ignition but due to a very long wet year prefered the WR heavy flywheel
    Have recently started started another build and have gone the 165 route but again with the WR although the later flywheel is lighter than the previous offerings! So far there is no comparison the 165 eats the 144 and mine really does run strong, I have been chopping up and trying various pipes for the 165 and cannot believe how different pipes totally change the way these 165s will run you can have a bottom / mid setup, a mid and up setup, or a absolute screaming top end motor (dont like it personally) the choice is yours, so for what my opinion is worth get the 165 you will love it and I really cant thank Walt enough for coming up with concept and all the hard work he must of put into them
  3. bsh7680 Husqvarna
    Cookeville TN
    12 CR 150
    Another question is the suspension, can I make the cr suspension plush enough for woods riding?
  4. Blakelpd5 Husqvarna
    Tigard, OR
    09 WRWB165
    What year CR? I have the closed chamber zokes on mine, and they seem to work great!
  5. Gotlabs Husqvarna
    Branchville, SC
    12 CR144 X 2!
    Me and my 14yo daughter race hare scrambles on CR144's and love them. I've raced in some pretty hilly areas down in SW VA with no problems. I came off of a WR300 and have no regrets. With a CR165, I can only imagine that would be as close to motorcycle heaven as one could get.
  6. R_Little Husqvarna
    NJ
    Any competent builder can make them super plush.
    My 45mm Zokes on my 125 are super plush.
  7. R-J van Hulst Husqvarna
    Cambodia
    Honda CB 400 Vtec 3
    WB165
    <100Kg
    165 CC
    normally this place was clutch abuse in the 125 cc form
    this is now 1st gear shift (no clutch use) to 2nd gear shift (no clutch use) to 3rd gear IMG_0413.JPG
    besides this its surprisingly how much this little one lugs
    your let it idle and just be gentle with the throttle and it crawls like a mountain goat over the obstacles
    effectively on a trail I think you will be a winner above all bigger displacement bikes you would try (especially when you throw endurance in the equation)
    its got power but it doesn't deliver it brutally so its much less wearing you out as a 250 or bigger would do.
    Robert-Jan
  8. bsh7680 Husqvarna
    Cookeville TN
    12 CR 150
    The cr is a 2011, the wr is a 2012
  9. R-J van Hulst Husqvarna
    Cambodia
    Honda CB 400 Vtec 3
    Mine is a 2002 and the motor is pretty much the same (seems that the gear box is wider though)
    Robert-Jan
  10. john01 Husqvarna
    Powhatan VA
    I had them in all trims starting with the stock CR125. Then a Walt HiComp 144 witch was fun and a big jump over the 125. The WB165 takes it up another level and like the rest said the 165 has awesome power that can lug or scream. My CR WB165 has a Rekluse EXP, 200 FMF pipe, and a SmartCarb and it's a package that really can do it all.
  11. Vinduro Husqvarna
    Mississippi
    Generally a good OFFROAD Suspension guy can make a CR suspension plush. BUT, typically a open chamber fork is plusher than a closed chamber fork. Easier to maintain also. A 144cc is good but a 165cc needs less shifting.
