125-200cc wr144
Discussion in '2 Stroke' started by dirtyface, Apr 5, 2015.
  1. dirtyface Husqvarna
    Woodbine GA
    KTM
    How many hours is to long on crank bearings . I have 121 hours on motor.
  2. Aviduser Husqvarna
    BC, Canada
    08 cr 165
    Whens the last time you did a top end? I will usually check the con rod for play when I do a top end/ or re-ring.
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    sometimes they last double that...pull the flywheel cover off and see if there is up/down play. they can last a long time if they never see dirt.
  4. R-J van Hulst Husqvarna
    Cambodia
    Honda CB 400 Vtec 3
    If the premix is a good oil and the air filter is maintained properly (so no little dirt particles enter) it last much much longer then that
    when replaced already and with good bearings a 300 or higher can be achieved.
    I did mine with mirco blue coated bearings.
    checking can be done on the flywheel as justintendo said.
    Robert-Jan
  5. dirtyface Husqvarna
    Woodbine GA
    KTM
    I change the oil and filter after every race . I was going to do the 165 this summer we have 2 more races.
  6. R-J van Hulst Husqvarna
    Cambodia
    Honda CB 400 Vtec 3
    simply check it but its in my opinion not an hour wear item but a working condition wear item.
    you keep it working in a happy environment it simply last longer.
    Robert-Jan
