250-500cc WR250 2000 suspension
Discussion in '2 Stroke' started by Michal Hajdu, Mar 28, 2021.
  1. Michal Hajdu Husqvarna
    WR 250
    Aprilia Rx 125 , Jawa 175 450 DeLuxe
    Front forks travell only 5 cm and then it bottoms out , what could be the problem? Maybe too much oil or something bent inside? I had the front wheel off and both of the forks have the same problem. Maybe bad service? Tried letting air out but didn't help. Should I disassemble it or leave to a mechanic in a shop?
  2. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    the bike in the picture is a 99 not a 2000
    you might try checking your oil level, did the problem just start or did you just buy it?
    steadydirt likes this.
  3. Michal Hajdu Husqvarna
    WR 250
    It started when I bought it. It says in the papers for the motorcycle that it's a 2000 but the plastics are a 99 yea.. (btw it's street legal)
  4. 2premo Husqvarna
    Northern NV
    tere was a comment on another thread from a member from down under that they did the 99-2000 thing there
    where are you located?
    back to your dilemma, the first thing I would do is to check the oil level in the forks, do you have an owners manual? the instructions are in there
  5. Michal Hajdu Husqvarna
    WR 250
    I've got the repair manual. It is there. I am from Slovakia , bought the motorcycle as is , didn't change the plastics but I like more the 99 look. Thought about swapping the forks for some newer or different but never done it before so I don't which forks would fit the best , or what to modify.
      File size:
      47.6 KB
      3
      File size:
      56.6 KB
      3
  6. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    Have you tried exercising all of the compression and rebound adjusters?
  7. Michal Hajdu Husqvarna
    WR 250
    Tried rebound adjustment , it works . Compression haven't tried for now but if it would be completely locked it woudn't move at all?
  8. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    If they don't move then there's a good chance that's your problem and they are going to need to come apart.
