250-500cc Wr250 6 speed
Discussion in '2 Stroke' started by QUATTRO, Apr 5, 2016.
  1. QUATTRO Husqvarna
    Hello
    I bought an incomplete gearbox from a wr360
    I have only the parts on the picture.
    Can someone tell me what I need more to make my wr250 six speed.
    I have a 2009 wr250
  2. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Thats not incomplete!
    Think there is one or two shims on the primary shaft but thats all you need!
  3. rancher1 Husqvarna
    WA
    You need the shift selector and the little tensioner for the selector as well as the little pieces for mounting the tensioner.
  4. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Those are in the wr250 gear box already an are a straight swap no?
  5. QUATTRO Husqvarna
    Oke thanks alot
    Do I need the gearselector to?
    I mean the complete axle with pedal
  6. rancher1 Husqvarna
    WA
    The pedal is the same.
  7. QUATTRO Husqvarna
    Thanks to all.
    I have almost all parts together
    What wil be recommended gearing
    14t 50 ore something
    I am riding now with the 5 speed
    13t 47 and is ok.
  8. rancher1 Husqvarna
    WA
    14 48 was stock on the 250
  9. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    13:48 stock on my 300 but 13:50 much better
    hesutton likes this.
  10. rancher1 Husqvarna
    WA
    I guess I should say that 14 48 was stock on the 250 6 speed motors. Different ratios, different gearing.
    shawbagga likes this.
  11. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Think 13:48 same as 360 im running 14:48 have a 15t sprocket for road use didnt fnd it much dfferent off road just used second a tad more.
  12. SmokeyExpress Husqvarna
    Canberra Australia
    2014 WR300, 1996 WR360,2013 WR125
    Juicy is right! I'm pretty sure you have everything you need! A few beers & some late nights in the shed! Better get cracking! It's a sweet upgrade over the 5 speed!
    ohmygewd and juicypips like this.
  13. Coyote Husqvarna
    Harrismith, South Africa
    WR300, WR250
    Yamaha XT660x
    I Purchased my WR300 with the WR360 6 speed gearbox installed-night and day difference if I compare it to my WR250!.. How can they market the standard close ratio gearbox as a 'WR'?.
    COYOTE.
    steadydirt likes this.
  14. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Im still in sixth before the end of my street on 360, lug around in 3-4 offroad unless im in twisties then its 2-3 anything else just lofts the front.
  15. QUATTRO Husqvarna
    We are building it together but I also needed the wr360 shift pedal axel. It has a different shift mechanism.
    Now it can work.
    Maybe newer wr360 do also have the newer shift meganism like the 2010 wr models.
  16. SmokeyExpress Husqvarna
    Canberra Australia
    NO, they don't. Same gearbox shift mechanism as the older ones
  17. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Well aslong as you got it too work thats the main point!
    Having owned a 99 250 and still own a 02 360 those shift mecs were the same as far as i could remember.
  18. rancher1 Husqvarna
    WA
    Husky changed the shift mechanism in 2002 on the CR 250 and 2004 on the WR 250. The 360 used the old style until the end. The old style also had 2 versions with the shift star on the end of the shift drum being large or small and of course the shift shaft to match. Hope this helps.
    juicypips likes this.
  19. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    That will be why my mechs were the same.
  20. SmokeyExpress Husqvarna
    Canberra Australia
    I learn something new ever day!
