250-500cc Wr250 dies when i give it throttle?
Discussion in '2 Stroke' started by AlexHusky23, Aug 26, 2012.
  1. AlexHusky23 Husqvarna
    England
    Husqvarna WR250 2011
    I went on my bike last week and after 1 lap of the enduro the bike died and would not start. I replaced the plug, the bike started fine but after another lap it died again. Any ideas what it could be? Alex
  2. Suamico SD Husqvarna
    NE Wisconsin
    TXC 250
    KTM 350 , Gas Gas Raga 300
    What did your plug look like when you took it out?
    Any changes to the bike (hardware)?
    Did you change oil brand or ratio, Elevation, humidity, major temp change?
    Does the plug have agood spark when clean?
    crappy pump gas?
    Air filter dirty/pluged?
  3. Idacurt Husqvarna
    hailey,ID
    07 WB177
    Scorpa 175
    ^ this and was any gas coming out of the overflow tube? maybe a float stuck open? with more info we will be able to help you better.
  4. R_Little Husqvarna
    NJ
    Try a new plug...sometimes they are bad when new.
    ray_ray likes this.
  5. broken biker Husqvarna
    1994 TE 610 2012 WR 300
    carefully check the spark quality.ducati energia ignition [made in india]has had probs that cause poor starting & kick back when starting.mine so bad push starting down the biggest hill did not work.
  6. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    was it wet?
    my 360 had a similar issue it sucked in water through a split boot would be running fine and cough splutter to death 5 mins half a lap no lap.. worth a check if not.
    if it was dry check privious posts all good
  7. Kyle Tarry Husqvarna
    Portland, OR
    2012 WR 300, 2006 TE 610
    Ducati Monster S2R 800
    Dude, this thread is almost one year old. Where did you even dig this up from? I think either by now he has fixed the problem, or pushed the bike off a cliff... There's no need to reply to these super old threads.
    bdl507 likes this.
  8. Cuclenutz Husqvarna
    1995 WXC250
    Unless its helpful to someone having a similar problem?
