250-500cc WR250 FMF Gnarly ?
Discussion in '2 Stroke' started by Jhunter, Feb 20, 2013.
  1. Jhunter Husqvarna
    Atlanta
    I'm thinking about adding a FMF Gnarly to my '08 WR250. Any first hand experience on the performance changes? My bike has quite a bit of torque and it pulls hard and all the way to the top. For some reason my bike doesn't have the 'power sign off' in the mid to top end like a lot of guys complain about with the later 250's & 300's. So, what should I expect for $225?
  2. huskybubba Husqvarna
    2007 wr250
    I have 07 wr 250 Love the gnarly with turbinecore 2. It was good with stock silencer, but better paired up.
  3. PowerKord Husqvarna
    Notheast Ohio
    2008 WR 250 Sold
    2014 Sherco SE-R 250
    I also have a 2008 WR250 with a Gnarly and Power Core II. I never road the bike with a stock exhaust. I would basically describe my motor the same way you describe yours. Pulls fairly strong from idle and has a screaming almost 125 like top. This is with the stock Mikuni carb. The only other mod to engine is to have the head shaved for more compression. As you probably already know, the Gnarly is much harder to dent than a stocker.
  4. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    if its similar to the platinum2 then a bit heavier but much stronger & looks sexy
  5. robertk61 Husqvarna
    Melbourne, Australia
    09 WR250
    +1 but I have a turbinecore on the back.
  6. nonamerider Husqvarna
    Oklahoma
    13/50 gearing gnarly pipe great for offroad. if you want more bottom end run stock silencer from older cr models. need more do pv adj. 50.5mm
    kx3089 likes this.
