250-500cc WR250 fork conversion
Discussion in '2 Stroke' started by CCP, Nov 9, 2017.
  1. CCP Husqvarna
    NJ
    04 WR250 11 WR250
    Is anyone running a new front end with 48mm KYB's on an older WR (04-06)?
    The triple clamp on the older bikes has a different offset so I was wondering how it steered with the new setup?
    Thanks
  2. taps Husqvarna
    TX
    '94 WXC360
    '15 RMZ450, '08 RM250, & '74 MX360
    I have been pondering the same thing. Just curious - What are the different offsets used?
    Thanks!
  3. CCP Husqvarna
    NJ
    04 WR250 11 WR250
    I'm pretty sure the older WR's were 15mm and the new ones are 20mm. My 04 had Ferracci 50mm clamps on it which were the same offset as stock. I measured, and had a machine shop make up some shims so I could use a set of 48 OC KYB's. I have a spare set of newer triples I would like to try instead of using the shims, but If it's not going to steer, or steer too quickly, it may not be worth it.
    I have an 04 and 11 WR's. The frames on both look the same to me. They even left the old steering stops on the steering head. I was never able to find out why Husky changed the offset on the triple. The zoke 50's and KYB's have the same offset as well, so the only change from the older bikes to the newer, would be the triple clamp offset.
    If i'm wrong on any of this please let me know - thanks
  4. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    I have a TC449 front end on my 06 WR250 including the triples. To be honest, I'm not sure how easy the swap was because I bought the bike from ajaxauto here on the Cafe. I'll have to ask if it was plug and play or if he needed to change the bearings. However, it works awesome!
  5. CCP Husqvarna
    NJ
    04 WR250 11 WR250
    Thanks - the bearings are not too much of a problem. Where are the steering stops? Added to the frame?
  6. taps Husqvarna
    TX
    '94 WXC360
    A picture is worth about 40 words in this case:
  7. CCP Husqvarna
    NJ
    04 WR250 11 WR250
    Thanks, That's an 06 frame? Looks newer to me.
  8. taps Husqvarna
    TX
    '94 WXC360
    That is a '12, but as far as I know, that is the only stop change. The '06 should have the stop on the head tube only. I think they got the bolt style stops in '10? I may be wrong, but I think that is right
  9. CCP Husqvarna
    NJ
    04 WR250 11 WR250
    Yeah, so I was wondering how he added the steering stops to the 06 frame since the old triples use the head tube stops and the new triples use the frame stops.
  10. taps Husqvarna
    TX
    '94 WXC360
    Ah, sorry. I thought you were asking where husky put the stops.
  11. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    My poor bike has been buried behind other bikes most of the year since I didn't race much. I'll be sliding it to the front to get it ready for next season and I'll take some pics for you.
