250-500cc WR250 Fork Seal Replacement
Discussion in '2 Stroke' started by Sandrsox, May 5, 2013.
  1. Sandrsox Husqvarna
    South Australia
    2005 Husqvarna 250
    09 TTR125LWE & 07 YZ125
    I was out riding at the local track today on my WR250 2005 and I have blown out my fork seal on the left hand side. :( How hard are they to fix myself and is there any special tools required?
  2. lankydoug Husqvarna
    MO
    WR
    TM 300en
    You can try cleaning the seal groove out by cutting an old credit card and making a cleaning tool out of it. Here is the fancy version of the tool that can be made with a credit card
    View: http://www.youtube.com/watch?v=8wlzfoVroSY&feature=pyv
    This is 1 of 2 videos
    View: http://www.youtube.com/watch?v=Y43k1qFVGW4
    This is 2 of 2
    http://www.youtube.com/watch?feature=endscreen&NR=1&v=C9ICr-DOmdk
    You can make your own oil level tool with a piece of fuel line an a big syringe from you local feed store. Than will cost you less than $10
    The seal driver is nice to have and I recommend buying it but you can make your own out of a piece of plastic PVC pipe.
    The seal bullet is not necessary, I use a couple wraps of electrical tape around the sharp edge and then throw it away when I'm done. You can also slip a plastic sandwich bag over the end of the tube and accomplish the same thing.
    I eventually bought the special wrenches but only because I'm always helping my buddies service their forks and I enjoy having the perfect tool for the job. Once you service your forks you will gain confidence and want to service them more often because fresh oil makes them work so much sweeter.
    I highly recommend using SKF seals. I bought mine at Halls and they drastically improved how my forks worked because they have a lot less stiction.
    Good luck.
  3. lankydoug Husqvarna
    MO
    WR
    TM 300en
  4. Sandrsox Husqvarna
    South Australia
    2005 Husqvarna 250
    What sort of forks are in my bike? It's a WR250 2004-2005, they are stock I'm fairly sure.
  5. lankydoug Husqvarna
    MO
    WR
    TM 300en
    You can identify them by the top end cap as explained in the video.
    Sandrsox likes this.
  6. Sandrsox Husqvarna
    South Australia
    2005 Husqvarna 250
    Oh Okay thanks :)
  7. Sandrsox Husqvarna
    South Australia
    2005 Husqvarna 250
    What brand and grade of oil would you recommend? I'm 65 kgs, don't do huge jumps but I do still jump it kinda hard.
  8. lankydoug Husqvarna
    MO
    WR
    TM 300en
    5w Maxima racing fork oil that comes in the black bottle with the blue label.
