250-500cc wr250 HTS question
Discussion in '2 Stroke' started by kiethy, Oct 4, 2010.
  1. kiethy Husqvarna
    Australia
    2001 wr250
    While out riding the selector spring snapped leaving the gear lever floppy. To get at it both clutch covers have to come off and the HTS needs disconnecting. Fortunately I discovered the main bolt into the left side valve loose however.
    1. How do I reinstall/time the gear since it was loose I couldn't mark the spot and really don't have a clue how it should be aligned?
    2. Is it ok to use loctite on the bolt?
    I have the owners and workshop manual but it is not clear. :excuseme::excuseme:
  2. kiethy Husqvarna
    Australia
    Sorted, quick cleanup revealed alignment dots:applause:
