250-500cc WR250 - is my rod bearing gone?????????????
Discussion in '2 Stroke' started by Kevin Sorce, Oct 13, 2011.
  1. Kevin Sorce Husqvarna
    Stockholm, NJ
    2015 TE300
    2009 Yamaha YZ250, Aprilia RST1000
    I have been slowly refurbishing my 99' WR250. The engine ran strong, shifted fine, no weird noises before I started this project. The bike was completely gone through front to back, cosmetics, tires, brakes, wheel bearings, plastic refinishing / graphics, etc, etc, etc. I also sent my fork and shocks to WER for a lowering and re-valve. So now finally ready to ride. I take it out today and while test riding it, after a warm up was sitting and adjusting the carb. I start to hear sort of pinging / occasional metallic sound, then it dies and would not restart. It still had good compression. I pull the spark plug and find the ground bent / pushed against the electrode. Is my rod bearing shot?!!! The bike did not overheat. It possibly had a little too much oil in the gear box but that should not cause this effect. I did drain the crankcase oil and there was no excessive metallic particles. Its almost normal to see some very minor sparkles in there, and the oil was clearish / grey which seems normal for this bike (and compared to other posts on crank oil). Is there anyway to tell if the rod bearing is shot without pulling the top end? I'm guessing I have to pull the top end and see if I have rod play? Also, my past experience is with Yamaha and Honda. If I have to pull the engine apart, whats the most difficult part and what special tools are needed for this engine? I'm thinking I have to find a case splitter and see if my flywheel puller is the correct size for this stator. Help! Thanks!
    mwood likes this.
  2. Kevin Sorce Husqvarna
    Stockholm, NJ
    2015 TE300
    BTW, the almost done bike is in the attached pic...........
  3. Motosportz CH Sponsor
    Dunno but the bottom end on those is historically VERY solid. Did you put a new plug in and try to fire it up?
  4. MOTORHEAD Husqvarna
    Mount Vernon, Indiana
    2014 YAMAHA YZ250
    It's possible, but you need to pull the top end and see what sort of damage there is. Obviously something went through the motor and hammered the electrode closed, which caused it to stop running.
    New reeds?
    If you can do a Honda you can do a Husky. The Husky motor is super easy to split.
    dartyppyt likes this.
  5. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    You won't find the answer in the gearbox oil as it has no direct connection with the crankshaft lubrication. You need to pull that top end and see what's going on.
  6. letitsnow Husqvarna
    mn
    FC250
    CBR600F4
    Any chance that you accidentally had put the wrong spark plug in?
  7. Kevin Sorce Husqvarna
    Stockholm, NJ
    2015 TE300
    Thanks for all the replies so far. No the wrong plug wasn't in. I had extra plugs but never changed it before yesterday since it ran fine. I also checked the plugs against an application chart. I'm hoping the damage is limited to the top end. The PO had replaced the reeds with Boysen reeds some time back. I have heard there is a life expectancy on them, not sure if a particle got sucked through. I was also contemplating if I had an over heat issue. The radiators were hot but, normal hot. I could touch them with my hand. However, what if the coolant wasn't moving through enough.
    When this all happened it was after a 5 minute ride, bike mostly idling so I could adjust the idle level, which crept up a bit after the ride.I then was hearing a periodic, but not constant ping, light metal sound here and there. Yes, that sound could have been "something" being digested, but what? Especially since it wasn't right after start up. I had already gone for a ride.
    Yea, the bottom line is I have to pull the top end. I'm just bummed since EVERYTHING else on the bike is new and had some significant rides / outing planned for the bike's refurbishing debut next week!
  8. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    A buddy if mine had a main jet go through his motor after cleaning the air filter. The main jet was either lying on the work area and got stuck to the filter, then fell in when installing the filter, or his toddler stuck it in the air boot while he was cleaning the filter. We'll never know, but I found the crushed main jet in the pipe.
    Even though I knew there was no way the main jet came out and got sucked through the carb and into the engine, I still had to look.
    Then again, it might be a rod bearing coming apart. Won't know until you get the top end off.
  9. pahusky Husqvarna
    Hummelstown, Pa
    '14 TC250
    '12 250XC '09 1200GSA KLR650
    Good looking piece of equipment...Sooner or later you'll have to pull it apart.
    But just for posting purposes, pull the pipe and take a peek in and let us know what you see. Piston still all there?, rings?, scoring on the back wall?, whatever...anything in the pipe?
  10. haulin husky7 Husqvarna
    SWVA
    13 txc310, 2000 wr360
    2016 TM 300en, 93 KLX650R, 1975 XR75
    The ride before mine went out it was acting like it was running out of gas( idling very fast and throbbing like a lawn mower) before the end of the ride, next day I washed the bike and let it dry a while then I started it and let it idle awhile, then rode it to check the mail and while crusing it locked up.
  11. oneal Husqvarna
    uk
    1999 wr 250 returned home.
    07 TE 450 2005 TE 450 1999 CR 125
    Well when the bottom end failed on my 99 wr 250, it was rebuilt useing a yamaha yz 250 rod kit from pro-x 99 to 09 are all the same so im told.
    hope this helps you out
    MOTORHEAD likes this.
  12. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    Good info. :thumbsup:
  13. glangston Husqvarna
    2012 Husqvarna TE 310
    2012 BETA 350 RS
    Counterfeit bearings are a big problem. Hard to detect. Perhaps your bike was rebuilt and got one.
  14. Kevin Sorce Husqvarna
    Stockholm, NJ
    2015 TE300
    Okay, see the pic! Pieces of piston were all over the place, which makes me want to split the cases no matter what. The fact that this is on the back skirt makes me think a reed or something sucked in. I didn't pull the reed cage out yet. Big end bearing has a tiny bit of play. I think the spark plug electrode smash was from a piece of piston though. Also when I opened the power valve cover a ton of oily goo poured out. Any clue on that? So besides a bottom end I'm probably going to have to have the cylinder sleeved to swapped. Its actually not too bad, minor scoring, but will have to be measured first.
  15. crille74 Husqvarna
    Sweden
    Husqvarna cr 125 2014
    Wow, nice piston:eek:
  16. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    Ugly!
    Can you tell if something went through the motor or the piston skirt just broke? Skirts breaking off there is common for high mileage pistons.
    Now you're going to have to pull the crank and clean and inspect it very carefully. I wouldn't even consider reusing the mains and seals, and I'd be very cautious of the lower rod bearing.
    It's very possible the cylinder can be re-plated back to stock bore.
  17. Kevin Sorce Husqvarna
    Stockholm, NJ
    2015 TE300
    So I have been finishing up the riding season on my Honda CRF :(. I immediately ordered the Pro-X rod kit since I know the Husky cases have to be split, new bearings and seals, etc. I will probably send my crank to Mr. Crankshaft since I heard a few good reviews about him. Not sure what I'm going to do with the cylinder yet. Maybe Eric Gorr will get that job. I'm open to all suggestions on the next steps of this endeavor!
