250-500cc WR250 - oil from the power valve cover
Discussion in '2 Stroke' started by Myles Walshe, Apr 1, 2013.
  1. Myles Walshe Husqvarna
    Hampshire - England
    2008 WR250
    Been and gone, TL1000R & FIreblade
    Hi All,
    Brand new here. I've got a 2008 WR250 with 19 hours on it (honestly, it's factory fresh) but when I gave it a short run (tarmac just to warm it up) I notice a small drop oil seeping from bottom right of the power valve cover. I wondered if the gasket has perished with age or lack of use, or is this nothing to worry about?.
    Many thanks
    Myles
  2. Aviduser Husqvarna
    BC, Canada
    08 cr 165
    I'd pop it off and give the power valve assembly a quick clean. Then seal it up with an rtv sealant. Or a new gasket gasket if u wish.
  3. Myles Walshe Husqvarna
    Hampshire - England
    2008 WR250
    Thanks, I will give that go. Having come from 4t s the sight of oil worries me but less so with 2t!
  4. Motosportz CH Sponsor
    Get used to it 2 stroke oil will gush from there, your head pipe when the o-ring goes bad, the pipe / muffler joint and out the muffler. :)
    Myles Walshe likes this.
  5. dan s Husqvarna
    united states N.J
    2013 wr 250 A-Class
    Don't worry about it they all do it. Just make sure its tight.
  6. Myles Walshe Husqvarna
    Hampshire - England
    2008 WR250
    Thanks for the info guys.. It' good to know it's not damaging anything. I’ve read about air leaks but I guess that’s anything before the air and fuel has gone into the cylinder, rather than waste out the other side.
  7. R_Little Husqvarna
    NJ
    The 125s have drain hoses.
    The 250/300 just leak it out there....
    I find if I use Amsoil dominator the spooge is reduced.
    Also low speed running makes more spooge.
    Myles Walshe and Motosportz like this.
  8. Long_Stroke Husqvarna
    Logan, Utah
    2011 WR300, 2013 WR144, 2020 FE501s
    1996 DR350, 2002 Aprilia Caponord
    Being new to 2-strokes I was pretty freaked out by spooge. I use Goo Gone citrus cleaner. It takes spooge off with a paper towel really easily. Soap and water just smears it around. I'm careful not to get it on the o-ring chain or near the brake rotors because its pretty strong stuff.
  9. Motosportz CH Sponsor
    PB blaster takes 2 stroke spooge off amazingly well too.
    panhandlebars and Myles Walshe like this.
  10. Myles Walshe Husqvarna
    Hampshire - England
    2008 WR250
    Thanks for all the ideas guys - great forum! :cheers:
