250-500cc wr250 speedo removal
Discussion in '2 Stroke' started by Myles Walshe, Nov 11, 2013.
  1. Myles Walshe Husqvarna
    Hampshire - England
    2008 WR250
    Been and gone, TL1000R & FIreblade
    Hi all
    I ride my WR250 in hare scrambles and don't have any need for the Speedo and headlight and would like to remove them along with the switchgear and associated wiring. Question is; Will this cause any adverse effects to the bike?. I'm sure I have read on here someone had a poor starting problem which was traced to the Speedo?? Unless I dreamed that bit :)
    Anyone stripped theirs of these?
    Many thank
    Myles
  2. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    should have no adverse effects on the electrical side as the lighting circuit is separate
    the speedo is just weight if you don't need it
    front number plates are cheap and lighter
  3. ohmygewd Husqvarna
    Melbourne, Australia
    Aprilia RSV1000
    250's still have a cable speedo? If so, unscrew the cable, tape up the cable mount and leave the speedo drive as a spacer?
  4. Myles Walshe Husqvarna
    Hampshire - England
    2008 WR250
    Thanks for the replies that is good to know. I'll be getting the Speedo and headlight off today.
