250-500cc Wr250 Strange idle Rich lean ?
Discussion in '2 Stroke' started by oneal, Apr 5, 2021.
  1. oneal Husqvarna
    uk
    1999 wr 250 returned home.
    07 TE 450 2005 TE 450 1999 CR 125
    Hi all, its good to be back again. After being in lock down for a year i finally managed to get out on my 1999 wr 250. ok let the story begin, I fitted a new HTM cylinder head along with fitting new boyessen dual stage reeds and a dyno port silencer cleaned out the gas tank and cleaned the keihin pwk carb.
    The bike starts and runs fine but has what feels like a off idle stutter like being rich if and then feels like its goes lean and hangs the on idle i did bump the pilot up from 40-42 and the best setting i can get on on the air mixture is one and quarter turns out but still not right.
    Any ideas or suggestions appreciated.
  2. Saabman82 Husqvarna
    1994 wxc 250
    1978Kz650 (810),1976 kz900,1977xs650
    Hanging idle sounds lean to me too.. i think youre on the right track there. Have you checked for air leaks (un-metered air)?.. Spraying something flamable (carb cleaner/gas) / propane/map gas has worked for me in the past. Id focus on the intake manifold, base gasket area, and head. Also worth checking the pipe o-ring. Just found a leak on my base gasket tonite and it only had 4hours on it... Good luck.
  3. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    since you replaced the reeds, you opened the intake, check your seal there
