250-500cc WR300 Light still lost
Discussion in '2 Stroke' started by mantrap, Nov 11, 2009.
  1. mantrap Husqvarna
    minnesota
    I have read all the posts on setting up the light kit and am still lost HELP!! I understand the grounds but can not figure out how to connect all the yellows. There is one yellow going from the stater to the regulator is this where I attach the resistor? then there are to yellows on the harness does one go to the yellow from the stator and the other to the other yellow on the resistor?
  2. PC. Husqvarna
    Beaverton, OR
    CR165 & CR144
    KTM500
    Did you get it sorted yet!?!?
    I can snap a few pics of my wiring if needed. I did not use the factory harness (or light), but the basic wiring is the same.
  3. mantrap Husqvarna
    minnesota
    No, will it cause any damage if not installed right? What is the resis
    tor for.
  4. mantrap Husqvarna
    minnesota
    Still lost what is the resistor for where does it go?
  5. mantrap Husqvarna
    minnesota
    Ok I got it hooked up except for this, do I need it? It seems to be working without it.
  6. Flyin Husqvarna
    Northern NJ
    WR 300
    I tapped mine in by the regulator, plug and play.
    I would assume its pourpose would be to help control voltage.
    Seeing that it came with the light and instrument kit I would think it's needed.
    Here's a pic of where I mounted it, ground wire is on one of the regulator bolts.
  7. mantrap Husqvarna
    minnesota
    Ok thanks I think I got it know
  8. mantrap Husqvarna
    minnesota
    I don't think the wr250 and 300 have a yellow wire going to the coil? There is a yellow wire going from the stator to the regulator.
  9. Troy F Collins Husqvarna
    alberta canada
    wr125
    GGEC 250 Honda RC51 CBR 1000rr CR125
    wow your right...I was speaking in terms of the wr 125 which I thought was the same.....
