250-500cc WR300 Rear Brake Issues
Discussion in '2 Stroke' started by Scott Goodman, Jun 9, 2013.
  1. Scott Goodman Husqvarna
    2012 Husqvarna WR300
    I just returned from a local Harescramble where I was in 1st place until the 4th lap, when my rear brakes became completely useless :mad: ! It had good fluid and pads, and were working great until the failure, so what gives? I had some guys tell me I might have boiled the fluid.
    I have been racing 25+ years and have never had a rear brake failure, but I can say this is the first solid-rotor I have ever used.
    I run Bel-Ray fluid, and have EBC pads (which are still in good shape after the fact). My own thoughts is this: put on a wave rotor, new pads and a in-line brake fluid cooler. Any of you Husky vets got some advise on this?
    Thanks :confused:
  2. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    I've read reports that the rear rotor is just too small, and that some people put on a rotor with a larger swept area, along with a caliper (or maybe the carrier) that will match.
  3. ajaxauto Husqvarna
    there are a few threads on this already Here is what you do Zip Ty racing makes a kit which is a caliper braket with shark fin the new brakets lets you mount a rear rotor the same size as all the other Huskys have Now with the bigger wave rotor you will have great brakes also rotor bolts direct to hub no more rattle Zip Ty or Halls Cycle has them I have had zero brake problems now
    lankydoug likes this.
  4. street2dirt Husqvarna
    World's Most Famous Beach
    12 TXC310, WR300, 85 125WR, 82 175XC
    BMW G650X
    Also, from the heavy rear brakers that I ride with, Motul600 is a brake saver.
    MOTORHEAD likes this.
  5. rancher1 Husqvarna
    WA
    Just put on a vented rotor.
  6. MOTORHEAD Husqvarna
    Mount Vernon, Indiana
    2014 YAMAHA YZ250
    Yes, you probable boiled your fluid. I've done it from time to time on all my bikes, until I went with Motul 600 and EBC carbon pads.
    Remember, you're on a WR now and going a lot faster than you ever have, so you are using your brakes harder. :thumbsup:
    454x and husky3002t like this.
  7. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    how much for the caliper bracket & oem 240mm(I assume?) disc ajax you know?
  8. Scott Goodman Husqvarna
    Thanks for the info guys! I contacted Zip Ty and they won't have any more bracket with fin made for 3 weeks (and Hall's was out of them). Since I can't wait that long (race before then), I ordered a wave disc from Race Disks in the UK! Zip ty recommended Spectro Brake fluid, as they found it has the highest boiling point, anyone used it?
  9. joedirt Husqvarna
    PA
    wr250
    I've boiled the brake fluid and lost the rear brakes on every bike I have owned.
    Good brake fluid and the red EBC brake pads are a must.
    K5PL5 likes this.
  10. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    I use the Race Disks from UK with the EBC X pads and Motul 600. I blue the rotor and char the pads on a regular basis, but they hang in there without fading.
    I hope you made arrangements to have the disk shipped a little faster, because mine took about a month to get here.
    ray_ray likes this.
  11. Scott Goodman Husqvarna
    If all goes well, the rear disk should show up in about 7 days :)
  12. Scott Goodman Husqvarna
    Ok guys, been beating my head trying to find the EBC X Pads for my '12 WR300, EBC says it should be a FA368X. I have looked at a lot of the bike shops on the internet, and some say that's the correct number for my bike, and others don't? Totally confused, can anyone tell me who they bought them from, and if my part # is correct?
    On a good note, got the brake fluid cooler coming from Slavens, and my local dealer is hooking me up with the Motul 600! Hopefully I can get it all together before my next race, and I don't lose my brakes after all of this :)
  13. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    FA208X if I remember right. I've got four pair coming that should be here Monday. Then I can verify that for sure.
  14. Eaglefreek Husqvarna
    Fayetteville,TN
    11 WR300
    I'm pretty sure that is the part number. It is listed wrong in many catalogs for some reason.
  15. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    Yeah, many of them list the same pads that the newer 4T's use for the 250/300. If you use an older bike, before 2008, you can usually find the right pads. They are the same pads that older KTM's used also.
    Here's a list of bikes that use that same pad:
    FITS KTM:
    EXC/EGS 125 (standard forks) 1994
    EXC 125 (Standard forks) 1995-1999
    EXC 125 (Upside down forks) 2000-2003
    EXE 125 2000
    LC2 125 1996-1998
    Sting 125 1997-1999
    SM 125 Supermoto 2000
    SX 125 (Standard forks) 1994-1999
    SX 125 (Upside down forks) 2000-2003
    EXC/EGS 200 (Standard forks) 1998-1999
    EXC/EGS 200 (Upside down forks) 2000-2003
    EXC/EGS 250 (Standard forks) 1994
    EXC 250 (Standard forks) 1995-1999
    EXC 250 (Upside down forks) 2000-2003
    SX 250 (Standard Forks) 1994-1999
    SX 250 (Upside down forks) 2000-2002
    EGS 300 (Standard forks) 1994-1998
    EXC 300 (Standard forks) 1994-1998
    EXC 300 (Upside down forks) 1999-2003
    MXC 300 (Standard forks) 1994-1998
    MXC 300 (Upside down forks) 1999-2003
    SX 300 1994-1996
    EXC 350 LC4 (Standard forks) 1994-1995
    EXC 350 (Standard forks) 1996-1997
    SX 360 (Standard forks) 1996-1997
    EXC 380 (Standard forks) 1998-1999
    EXC 380 (Upside down forks) 2000-2003
    SX 380 (Standard forks) 1998-1999
    SX 380 (Upside down forks) 2000-2003
    Duke 400 LC4 1994-1998
    EGS 400/EGS-E/LSE (LC4 Enduro) 1996-1999
    EXC/EGS 400 (USD) 2000-2002
    EXC 400 Racing (USD) 2000-2003
    XC/EXC 400 2004-2007
    LC4-E 400 Enduro 2000-2001
    SC 400 (Supercompetition LC4) 1996-1999
    SX 400 (Upside down forks) 2000-2002
    EXC 440 1994-1995
    SX 440 1994-1995
    EXC 450 2003
    SX-F 450 2007-2008
    MX 500 1995
    EXC 520 2001-2003
    SX 520 2001-2003
    EXC 525 2003
    MXC 525 (Desert Racing) 2004
    MXC 550 1996
    Duke 620 LC4 1994-1998
    EGS 620 Enduro/EGS-E/LSE 1996-1999
    EGS-E 620 Adventure/Rallye 1999
    LC4 620 SC Supermoto 2000
    SC 620 Supercompetition 1996-2000
    SX EXC/EGS 620 1995
    SX 620 1996-1999
    LC4 625 SC Supermoto 2002
    LC4 625 SC Supercompetition 2002
    SMC 625 2005-2006
    SXC 625 2003-2004
    SXC 625 2005-2006
    Duke II 640 Orpheus/Titan/Lime 2001-
    Duke II 640 Black/Orange 2002
    LC4-E 640 Enduro 2000-2004
    LC4-E 640 Supermoto 2000-2004
    LC-4 640 Adventure 2001-2003
    LC-4 Adventure 2004-2005
    LC-R 640 Adventure R 2000
    640 Duke 2003-2006
    SMC 640 LC4 2005-2006
    SMC 660 Supermoto 2003-2004
    SMC 660 2005-2006
    690 Rally Factory Rep 2007-2008
    690 Enduro 2008
    690 SMC 2008-2009
    690 SMR 2007-2009
    690 Supermoto 2002-2008
    990 Superduke 2005-2009
    FITS ATK:
    125 (2 Stroke Enduro) 2003
    250/260 (2 Stroke Enduro) 2003
    250 (2T) 2004
    370 (2T) 2004
    450 MX 2007
    450 XC 2007
    Enduro 450 2007
    500 Enduro 2003
    500/600 Super Motard 2002-2003
    500 (2T) 2004
    All models 1997-1999
    600 DTM Dirt Track Motard 2003
    605 Enduro 2003
    620 (2T) Intimidator 2004
    700 (2T) Intimidator 2004
    FITS BMW:
    F 800 GS 2008-2009
    FITS GAS-GAS:
    Enduros 125/250 2000
    FITS HUSABERG:
    All models (fixing pin at end of brake pad) 1995-1999
    All MX/Enduro models (Brembo 2 piston caliper ,260mm front disc) 2000-2008
    All Supermotard (Beringer 4 piston caliper-front disc) 2000-2003
    FS Supermotard (Beringer/FTE 6 piston caliper 310mm front disc) 2004
    FS Supermotard (FTE 4 piston radial caliper) 2005-2008
    FITS HUSQVARNA:
    CR 125 1995-2004
    SM 125 1998-2000
    SM125 S 2002-2009
    WR 125 1995-2009
    WRE 125 1993-2000, 2002-2009
    CR 250 1995-2004
    TC 250 2002-2003
    TE 250 2002-2005
    WR 250 1995-2005
    TE 350 1995-1997
    WR 360 1995-2002
    SM 400 R 2002
    TE 400 2002
    TE 410 1995-2000
    TE 410E 2000
    SM 450 R 2003-2006
    TC 450 2003
    TE 450 2003-2005
    SM 510 R 2005-
    TC 510 2004
    TE 510 2004-2005
    SM 570 R (4 bolt front disc) 2001
    SM 570 R 2002-2004
    TC 570 2002-2003
    TE 570 2001-2004
    LT 610 (6 bolt front disc) 2000
    SM 610 (6 bolt front disc) 1998-1999
    SM 610 R 2000
    SM 610/S (4 bolt front disc) 2002-2006
    SM 610 S (Radial caliper) 2006
    SM 610 IE 2007-2009
    TC 610/E 1995-1999
    TC 610 2000
    TE 610 2000
    TE 610/E 1995-2000
    TE 610 E 2002-2003
    TE 610/IE 2006-2009
    SMR 630 2006
    STR 650 CRC 2007
    FITS T.M. DIRT BIKES:
    MX Models 85/100 2002-2003
    FITS VERTEMATI DIRT BIKES:
    495 1999-2002
    C 450/500/570 (MX) 2003-2004
    E 450/501/570 (Enduro) 2003-2004
    S 450/501/570/E (Super Motard) 2003-2004
    SR 450/SR 600 Motard Racing 2003-2004
    FITS VOR DIRT BIKES:
    SM-E 450/530 2004
    MX 450/530 2004
    EN/EN-E 450/530 2004
  16. Scott Goodman Husqvarna
    Hey Motorhead, where did you get the compatability list from? Thanks also for the help!
  17. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    cyclebrakes.net
    No problem. :thumbsup:
  18. zilly Husqvarna
    Yakima
    09 wr300, 04 cr125
    Ok, I give. I have been dealing with fading rear brakes for awhile and have changed the fluid, changed the pads etc and still having issues. I am sure I boiled the fluid on a track day this spring and so changed fluid and pads but on a trail ride this weekend my rear brakes went away again.
    I just ordered a galfer vented wave rotor that is supposed to fit my 09 wr300. My question is does this disc mount to the wheel differently i.e. different bolts etc.?
    I know the stock one is kind of unique because it "floats" or more accurately rattles back there so I am not sure if I have to change anything for this new rotor.
    I should have the rotor this week and I am trying to avoid any delays because I am anticipating being able to go on a ride this weekend!
  19. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    What fluid and pads are you using?
    Are you sure you are getting the air out of the system?
    Are you purging the system until you get good clean fluid out the bleed?
    I'm not sure about the Galfer rotor, it may use the stock floating mounts. If not, I'd say it will come with bolts.
  20. zilly Husqvarna
    Yakima
    09 wr300, 04 cr125
    I am using ebc pads and motul fluid. I am trying my best to get
    the air out and I keep coming back to thinking I have blued my
    rear disc.
    However the one thing that pops in my head right now is that I
    layed my bike over last weekend to wash it. Maybe air got in
    it then?
