250-500cc wr300 squish?
Discussion in '2 Stroke' started by Glenn haynes, Mar 14, 2014.
  1. Glenn haynes Husqvarna
    western pa
    2012 wr300
    13 yz250f 08yz85 11ktm 65 09 ktm65
    Anyone know what the squish is supposed to be set at? what is the stock base gasket size? I have a .08 on it now.
  2. nonamerider Husqvarna
    Oklahoma
    wr250 .90 cr.80 i run the .03 basehusky part. i know you have a 300 i have heard they are the same. cr stock .05. wr .08.i run squish on huskies .50 to .70 so you dont have to increase volume in the dome. i have tested at the 1mm mark and didnt like it.
    Glenn haynes likes this.
  3. flyingbob Administrator
    USA
    01&02WR360_02WR250_02CR250_12WB165
    01 VOR400_07 TM450_22 GG250_07 Tuono
    Have you ever compared a squish setting to the Husky manual dial indicator setting? Thread hi-jack - - - How about a WR360 squish setting?
  4. Glenn haynes Husqvarna
    western pa
    2012 wr300
    how do you use a dial indicator to set squish? I've always used solder.
  5. Hurky Husqvarna
    Spain
    WR300 2010
    Yamaha WR480F 2008
    Please excuse for picking up this thread ...
    So the WR300 2010 is using a 0,8mm base gasket stock ? I'm planning to do a top end in the near future and am buying the parts, not sure what base gasket size to get... If she comes with a 0,8mm, is it a good or a bad idea to lower to a 0,5mm to gain a little bit compression / low end ?
    Regards.
  6. russell timmins Husqvarna
    2011 wr 300
    2006 yz450f
    Does anyone know the torque settings for the cylinder and head for a 2011 wr 300?
  7. Hurky Husqvarna
    Spain
    WR300 2010
    Yamaha WR480F 2008
    From the WR300 2010 manual: (2011 should be same)
  8. Hurky Husqvarna
    Spain
    WR300 2010
    Yamaha WR480F 2008
    Can someone please give some inputs about this ?
    Looking from the outside of the cylinder and with the help of a feeler gauge and a caliper it seems that I have a 0,5mm gasket right now...
    Much appreciated ;)
