250-500cc WR300 starts good when cold. But when hot needs several kicks.
Discussion in '2 Stroke' started by 9880sts, Mar 22, 2015.
  1. 9880sts Husqvarna
    Boronia Victoria
    TE511 2013
    GAS GAS EC 300 2006
    Hi Guys ,
    just bought this bike with 1200km and love it . It starts at first kick when cold . But when hot it is a real bitch.
    It takes several kicks to get it going.
    Sparkplug is nicely brown coloured.
    I run Motul 800 40;1
    what wre the suggestions and what can i do.
    i hear a lot about different Carbys. Well bike pulls good and has lots of torque.
    Vibration is next to nothing...
    Thanks for the input.
  2. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    when you say starts fine cold
    do you mean with the starting aid? (that thing you pull up)
    typically if you set the air mixture at a warm idle it will start easy when warm too
  3. Long_Stroke Husqvarna
    Logan, Utah
    2011 WR300, 2013 WR144, 2020 FE501s
    1996 DR350, 2002 Aprilia Caponord
    Back before I had a Lectron carburetor, the Mikuni needed just a tiny crack of the throttle to start when hot. I'd hold the front brake lever with one finger to keep the throttle just barely open while kicking. Worked like a charm.
    R_Little and 2premo like this.
  4. Schrup Husqvarna
    Tacoma
    2013 WR300
    Do you know if the PO rejetted the carb? I bought a JD kit for mine, but it's always started fine. I also have a couple of questions for the brain trust if you don't mind. First is that when my bike is warm, I start it with the throttle full. It kicks easier & starts easier. The dealer showed me the whole warm starting sequence of light kick to the top of the stroke, tip the bike to drain carb, crack the throttle three times & kick it hard, but my method never fails. Second, sometimes my bike can be a little tough to cold start so I cheat with a squirt of ether if I'm feeling lazy. Are either of these practices bad for my bike? This is my first 2T.
  5. 2premo Husqvarna
    Northern NV
    i highly recommend agains ether
    cold start: hold kill button, fuel enricher (starting aid) on also improperly called a choke)
    kick slow 3 times, release kill button kick with authority, starts every time for me
    warm start: crack throttle barely, kick with authority
    Schrup likes this.
  6. Motosportz CH Sponsor
    sounds like the pilot jet is to rich.
    R_Little and justintendo like this.
  7. Idacurt Husqvarna
    hailey,ID
    07 WB177
    Scorpa 175
    How many turns out is your air/fuel screw?
  8. utopia Husqvarna
    Jackson, WY
    WR250, WXC125
    What he said.
  9. braddenning Husqvarna
    Northern NJ
    2011 WR 300
    2013 HUSABERG FE 350 ,2014 KTM 300XC
    Do you have a headlamp ?
  10. 9880sts Husqvarna
    Boronia Victoria
    TE511 2013
    GAS GAS EC 300 2006
    yes and what does it have to do with ? its switched off
  11. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    Many have reported prob's starting with head light on. And, what Kelly said. Basically, any prob's with the stock Mik, get a JD jet kit and you should be able to sort it out.
    :cheers:
    Dirtdame likes this.
