125-200cc WR300 too much bike
Discussion in '2 Stroke' started by Sph123, Mar 31, 2014.
  1. Sph123 Husqvarna
    West Jordan Utah
    2017 Husqvarna TE250
    I had an interesting phone call this weekend. A gentleman called me this weekend asking if I still had my TXC310 for sale, when I told him no, he asked me if I knew much about the WR 300, to which I said a little bit.
    Basically, he said it was way too much bike for him, 1st and 2nd were useless because there was too much power but he loved the top end for the desert roads he frequents. I tried to get a little more information from him so I could help him as much as I could. I told him to call up ZypTy racing to see if there was a flywheel weight he could add on to it to tame it or even if there was a spring in the exhaust power valve( they have power valves right).
    This is a 2012, he didn't get the rebate when he bought it and can't sale it without taking too much of a hit.
    You guys got any advice for him? I'm sure he'll be calling me back. . I'm sure if anybody was interested in trading there 310 for his 300, I'm sure he would be very interested.
  2. JRod4928 Husqvarna
    Pittsburgh, PA
    2012 CR165
    Can't you swap top ends with a 250 on this bike as well? Can someone verify or deny this?
  3. JRod4928 Husqvarna
    Pittsburgh, PA
    2012 CR165
  4. Sph123 Husqvarna
    West Jordan Utah
    He actually lives in Evanston Wyoming so not too far from that guy. With the low hours on the bike, I think he is looking at getting closer to 4900 for the bike, i'll have to direct him to that post.
  5. JRod4928 Husqvarna
    Pittsburgh, PA
    2012 CR165
    The guy has a TXC310 as well, maybe he'd do a trade + cash deal? Curious to see where this goes
  6. fletchman45 Husqvarna
    park rapids
    Yes. 250 can be swapped. But with right gearing and pipe and jetting and flywheel (if needed) should be able to make it work well! Is a beast to kickstart compared to a WR 250
    R_Little likes this.
  7. shrubitup Husqvarna
    Seattle WA
    he could try a G2 Ergonomics throttle tamer throttle cam. Makes it less abrupt especially in the lower gears. I like mine stock however. :)
    Clete and Dirtdame like this.
  8. Kyle Tarry Husqvarna
    Portland, OR
    2012 WR 300, 2006 TE 610
    Ducati Monster S2R 800
    I'd love to sell my 610 for $20,000, but that doesn't make it realistic. ;) No way he is getting $4900 unless he finds a VERY clueless buyer.
    I'd also recommend the G2 Ergo throttle cam. I have one on mine and it's plenty snappy even with the "laziest" cam; the stock one was way too much for the woods for me. Jetting can also make a difference in power delivery.
    I wonder what the guy expected when he bought a 300cc 2-stroke...
    Clete and JRod4928 like this.
  9. Cosmokenney Husqvarna
    North Auburn, CA
    '17 TX300
    Yamaha FZ-09
    Too bad. I'm looking for one. But I need to get a deal. I have a CRF 150 I could trade + some $s. ;-)
  10. Sph123 Husqvarna
    West Jordan Utah
    He is in his 50's. hasn't really ridden since the early 80's when he had a Bultaco.
  11. Chums Husqvarna
    I'd like to discontinue my account
    Stealy makes a FWW that helps a bit and a gnarly pipe helps a little a rekluse could maybe help some by allowing him to run a gear high. By the time you did all that you'd still have a 300 2 stroke so it might be money well spent to just go for the 250 kit.
  12. JRod4928 Husqvarna
    Pittsburgh, PA
    2012 CR165
    I bet someone, maybe on this forum, would be willing to trade their 250 top end for his 300 top end, straight up. Problem (maybe) solved.
  13. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    Hmmm....not what I have found with my 300. First and second seem pretty wide, and bike goes bup bup and tip toes over gnarley stuff if you are just gentle on the throttle. I'd agree that if throttle modulation is a problem, a smaller cam on the throttle tube would probably be just the ticket.
  14. oregonsage 4st Clerk
    Dry Washington
    FX450
    Yamaha DT400 x 2, BMW G310R
    Lectron or a R-B Designs carb setup can help make these more tractable, then maybe gear it up a bit. I do agree that the 300 is a whole lotta power and as delivered is probably an open spaces bike, but all the suggestions above would make it mellower. He may also find that a proper suspension setup will make it easier to ride. I find that the WRs are soft in front and stiff in back from the factory.
  15. ks9mm Husqvarna
    NJ
    2015 TE 125
    2014 Beta 300RR
    now I wonder if my 300 is underpowered :confused: :confused:
    another idea is to use rekluse. this way he can safely ride gear higher..
  16. R_Little Husqvarna
    NJ
    For that reason alone I'd take a 250 over a 300!
  17. oregonsage 4st Clerk
    Dry Washington
    FX450
    Ive ridden both and prefer the 250.
  18. oregonsage 4st Clerk
    Dry Washington
    FX450
    Why is this thread in the 125-200 section?
  19. msmith345 Husqvarna
    Shawnee, KS
    '12 WR250, '92 360, '80 390
    '72 Yamaha R5, '17 SV650
    Yep, like others have said:
    Definitely a G2 throttle cam to prevent the whiskey throttle moments. I put mine on to keep me fresh and minimize mistakes at the end of a race where I might think I'm pulling in the clutch, but mine whole left arm is really just a spasm of muscle locked to the bar. ~$100
    If he is only going wide open type, go to a 14 tooth sprocket up from, with the 48 in back. This will take some of the hit off, but help in the higher speed stuff. It takes a lot more clutch use in the gnarly 1st/2nd gear stuff. ~$20
    Lectron to smooth things out all around, as a side it will give more for the fast desert road stuff and mpg. ~$380
    He could swap to a 250 top end. It will rev quicker, and will be a faster bike once rolling, but it will have a lot less grunt. I'm not real satisfied with the downgrade on mine. It still has some grunt to it, but not so much you can be lazy and get away with nearly everything with it like on the 300. ~$ depends on if you can find used or pay $$$ to the dealer for new
    And suspension to keep him fresh for longer, mistakes mainly happen when you're tired, so don't get tired so soon.
  20. Motosportz CH Sponsor
    Good list going. A Rekluse might be his answer. Mellows them out and makes them much less abrupt and EZer to manged and is like cheating.
