125-200cc WRE 125 2000 rattle after engine rebuild
Discussion in '2 Stroke' started by mr.freezer, Aug 26, 2015.
  1. mr.freezer Husqvarna
    SM 125 2000
    Ducati Monster 620 ie, Suzuki RM 125
    Hi guys.. I have rebuilt WRE 125 2000 of my girlfriend... All bearings and seals are new... new piston, new crank set... When I fire it up it rattles at idle, but no rattle at higher RPM... I have noticed, that one or two of springs in balancing shaft wheel are broken.. Could this be the cause of idle rattle?? What else could cause rattle just at idle?? Thanks a lot
  2. mr.freezer Husqvarna
    SM 125 2000
    nobody can help??
  3. fran...k. Husqvarna
    eastern ct
    This is kind of a dual sport or entry level street legal in europe bike isn't it? Is there a powervalve and governor?
  4. mbb Husqvarna
    Malaysia
    Cagiva Stella 125, Cagiva Planet 125
    Replace the broken small springs and most important things ensure all 3 balancing markings are properly aligned.
  5. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Does the rattle disapear with the clutch pulled in?
    And yes replace springs and make sure its aligned!
  6. mr.freezer Husqvarna
    SM 125 2000
    So... all marks aligned... spings replaced.. still rattling at idle.. if I just touch the gas, the rattle disappears...
  7. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Not the kick start hitting your exhaust, any way you can narrow down the area its coming from?
    My bike sounds like it's going to grenade but after hearing several 360's I put it down to piston noise.
  8. mr.freezer Husqvarna
    SM 125 2000
    not kick start.. it is coming from somewhere near crankshaff, but crankshaft is new... everything is fine.. bike is really powerfull, just that rattle
  9. mr.freezer Husqvarna
    SM 125 2000
    I have just wathed this video and there is rattle too at idle... the same on mine... maybe it is normal
  10. marklodeweges Husqvarna
    2x cr125
    Maybe you're nut on the crankshaft came loose. or the nut on the clutch basket.
  11. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Well the engine isn't under a bonnet so any noise it makes is open to be heard, I put that rattle in the vid down to gearbox chatter as the gears mesh and catch up with each other it will go away under load.
  12. mr.freezer Husqvarna
    SM 125 2000
    so nothing to be worry about??
  13. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    I would record it in your phone and ride it for a while see if it gets worse, of there's plenty of power and the noise is the same after 10 hours then it's normal.
    Who did the engine work as stated could be something left loose. But two strokes are noisy.
  14. mr.freezer Husqvarna
    SM 125 2000
    I have ridden it for few hours without change... engine work done be me... tripple checked everything.. nothing loose
  15. mr.freezer Husqvarna
    SM 125 2000
    So today bearing on crank crashed... it was koyo.. brand new... 300km on it.. how to get it from crank??
  16. mr.freezer Husqvarna
    SM 125 2000
  17. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Brand new?!? That's got to be a fake, where did you get the bearings from?
    Strip the engine down and either use a bearing puller or go very gently with a grinder on the knackered race.
    Dam that's not good.
    P.s. I always buy bearings from a reputable supplier not Off eBay.
    Were the oil lube holes clear when you re-assembled
  18. mr.freezer Husqvarna
    SM 125 2000
    It was not bearing on crank.. but main bearing on crankshaft..
  19. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    You mean big end?
    Well that's a new con rod required.
    Didn't know koyo made big end bearings.
  20. Miezie666 Husqvarna
    Germany
    2x YZ 125, 1x YZ250 2005, XT600 2KF
    New big end bearings can go wrong just after a few hours if: they are sold as Hotrods/Wiseco parts, if they are running with not enough side to side play or if the engine cases are not lined up properly.
    I had several Hotrod Crank failures on different bikes,brands and users- DONT BUY THEM!
    I also had a Bigend Failure because someone pressed the crank and did not check the side to side play.... big mistake!
