Took my rear wheel off yesterday for a new tire and it was brutal trying to get the nut removed. Seems as though the prior PO crossthreaded it somehow then patched it up with tons of loctite when reinstalling and meshing the threads on even more. Threads are all eff'd up. Did some online parts searches and the PN 8000 A2788 is extremely high priced. Same part number for the TXC 250's and likely others as well. If anyone knows of any, drop me a note - already did searches on eBay. There was one on here recently but sold. Thanks.
I've looked on Ebay since I wanted to get the SM axles so I could put on some sliders (they don't have the pull lever welded on). Did you not find any there? A search on 'husqvarna 610 axle' turns up half a dozen--a couple of which look like they're from Bill's.
Thanks - saw those. Not sure how long those SM axles are....diameter of 25mm is same. My TE axle measures 273mm in length from end to end.
Thanks - if you can measure, great!! Mine is 273mm long and should be the 25mm diameter. I found the following: 2006 SM610 2007 TC450 2000 TE610 Of course, none have the bar welded on the one end, but I can live with out it. I asked those sellers listed above to measure but have yet to get responses.
Thanks - I would definitely take it. Does it have the nut by any chance? How much? Shipping to 80108. I can send funds via PayPal if you PM me your email address....or you can invoice me, whichever is best for you. Thanks a lot!!
