250-500cc wxc 250 front sprocket - have a pic or measurements?
Discussion in '2 Stroke' started by dhallilama, May 30, 2015.
  1. dhallilama Husqvarna
    '96 WXC 250
    many. i'm addicted.
    '96 WXC 250... does the sprocket have any offset, or is it flat?
    i misplaced (or tossed) the front sprocket from mine when tearing the bike down (it was missing a couple teeth). walking in my garage today, i saw a stack of sprockets for my Yamaha IT250... turns out the splines fit nicely on the Husky's shaft.
    i haven't checked chain alignment yet... it'd be sweet if the alignment is good as i've got a bunch of these sprockets from 12t through 18t
  2. Big Timmy Husqvarna
    (South Eastern) AZ.
    Just look it up on the JT Website. This was the listing for the Husky 96 250s
    It didn't have a listing directly for the 96 WXC 250
    Husqvarna 250 CR — USA
    Off Road
    1995 to 1997
    Front Sprocket
    Part No. Teeth
    JTF507 13
    Available Sizes
    13, 14, 15
    Rear Sprocket
    Part No. Teeth
    JTR822 48
    Available Sizes
    41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53
    dhallilama likes this.
  3. dhallilama Husqvarna
    '96 WXC 250
    many. i'm addicted.
    well hole-e-chit.... I didn't even think of that. thank you!
    oh well, looks like these won't work. on the plus side, sprockets are cheap anyway...
  4. Big Timmy Husqvarna
    (South Eastern) AZ.
    Yes your right, the JTF569 sprocket is flat on the engine side anyway that you have pictured. This would affect the alignment.
    Front Sprocket
    Part No. Teeth
    JTF569 13
    Available Sizes
    10, 11, 12, 13, 14, 15, 16, 17, 18
  5. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    the jt are good stuff for the money. i always run their steel front and rear sprockets. the rears last a looong time...
  6. dhallilama Husqvarna
    '96 WXC 250
    many. i'm addicted.
    offset is 3mm with the shoulder... enough to throw off the chain alignment.
    JT do make great sprockets... have their steel front/rear on all my bikes. lasts a lot longer than aluminum, that's for sure...
  7. Big Timmy Husqvarna
    (South Eastern) AZ.
    Recently picked up a 48 and a 49 rear for my FE 501 myself. For about what a single aluminum sprocket costs. I am already running the 48 on the rear now and the difference in weight, changing from the stock aluminum sprocket to the JT Steel sprocket is negligible.
    For what I do with the bike, It will last a hell of a lot longer as well.
