250-500cc Wxc250 BR8ES plug ok?
Discussion in '2 Stroke' started by WXC250, Sep 18, 2014.
  1. WXC250 Husqvarna
    Burtonsville, Md
    95 WXC 250
    I did a plug chop test the other day and it looked pretty good tannish brown. Gap was between .60-.65.. I looked in the reference guide and it showed this is 1 step hotter than stock. What does that mean? Should I go back to stock? Thanks
    I bought the bike with the plug boot broken off the coil wire.. I shoved it back on the boot with no problems but I'm wondering if this would cause any future issues....
    Thanks for any help, really enjoying this bike
  2. lankydoug Husqvarna
    MO
    WR
    TM 300en
    A BR9 is one step cooler but the 9 will foul easier unless you ride it really hard and have it jetted perfectly. I run a BR8 in my WR250 and usually change it once a year because it gets lead fouled from running leaded VP110 race fuel.
    If your color is good like you say and you aren't experiencing detonation (pinging/knocking) then the BR8 is the correct heat range for what you are doing.
  3. WXC250 Husqvarna
    Burtonsville, Md
    95 WXC 250
    That is good to know. I was going by this
    Typical Plug for Husky 2-Stroke Bikes:
    BR9EG = fine electrode (Stock)
    BR9ES = regular electrode
    BR9EIX = iridium electrode
    Gap = 0.60 mm = 0.0236"
    Alternative Plug:
    BR8ES = 1 step hotter, with regular electrode
    BR8EG = 1 step hotter, with fine electrode
    BR8EIX = 1 step hotter, with iridium electrode
