250-500cc WXC360 counter sprocket bolt torque?
Discussion in '2 Stroke' started by Dauer, Nov 29, 2015.
  1. Dauer Husqvarna
    Western NC
    1992 WXC 360
    '89 Yamaha TDR250, '01 ATK 605
    As the title states I'm curious what the tightening torque of the counter sprocket bolt is? I searched this forum but couldn't find specific info. I have a manual for a '99 WR360 (mine is a '92) but am unsure if the tightening torque value is listed, the primary gear nut is listed but not sure if that is what I'm looking for because the counter sprocket is held on by a bolt.
    Also, what is the desired technique to torque the bolt? I took a stab at 40 lb-ft dialed on the wrench and tightened while holding the rear brake, this succeeded in snapping the bolt :(. Fortunately it was easily extracted, 40 lb-ft doesn't seem excessive to me, perhaps the bolt was fatigued? Should Loctite be used?
  2. rancher1 Husqvarna
    WA
    40 sounds high to me for such a small bolt. I will try to look at my old manuals.
  3. Dauer Husqvarna
    Western NC
    1992 WXC 360
    Thanks, that'd be great. It would stand to reason that 40 is too much considering the failure.
  4. rufctr Husqvarna
    arizona
    1995 WXE250
    2003 KX500 - plated
    40 definitely sounds high, I think about 20-25 with blue loctite is right
  5. Dauer Husqvarna
    Western NC
    1992 WXC 360
    Well, chalk another one up to ignorance on my part. Thank you kindly sir.
  6. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    it is as Rancher says lower, but WAY more important is red locktite
    had one fall out and the sprocket fell off and the bike skidded to a stop
    torque is based of fastener stretch values
  7. Dauer Husqvarna
    Western NC
    1992 WXC 360
    Makes sense to me. Correct me if I'm wrong but red locknite will most likely require an impact wrench to remove? Which won't be an issue considering I had to use one to remove the old sprocket.
  8. 2premo Husqvarna
    Northern NV
    better than coming off in the middle of nowhere :eek:
  9. rancher1 Husqvarna
    WA
    The OEM sprocket bolt came with some kind of thread adhesive that made use of loctite unnecessary.
  10. 2premo Husqvarna
    Northern NV
    that is common in heavy duty stuff too, but it is s throwaway world with those fasteners
    to reuse we use loctite
  11. Dauer Husqvarna
    Western NC
    1992 WXC 360
    All valid points, I will head the advice of the many knowledgeable members of this forum. Thanks for all the info guys :cheers:
