X2 light on TE Husqvarnas
Discussion in 'Motosportz' started by Dust_Buster, Jan 15, 2010.
  1. Dust_Buster Husqvarna
    Santa Rosa
    I'm interested in what people have done for the lower mounting on Trailtech X2 lights for late model TE's. I'm much better at copying than creating.
    Thanks
  2. Norcalslowpoke Husqvarna
    I got out the hacksaw and cut some of the black fender support away.
    IIRC, maybe an 1.5" or so.
    Does not look too bad, but I'm not that picky.
  3. Motosportz CH Sponsor
    - Remove the fender brace and use the plate with pins
    - Screw the plate with pins to the top of the fender brace (makes the light a little high)
    - Use the down pins and drill holes in the fender brace for them
  4. ElDiablo Husqvarna
    I skipped the pins and the light is perfect.
  5. jeffchri Husqvarna
    Seattle, WA
    It certainly works okay without the pins, but I found the light angle too low and too movable with bumps. The pins solve that.
  6. Zestymac Husqvarna
    Joisey
    X2
    This thread needs PICS!!!:thumbsup:
  7. ElDiablo Husqvarna
    It depends what you ride. For me riding at night in the desert and standing up was perfect. I never hit more than 50mph. In slow technical it was great too as you need a lot of light right in front of you. I also plugged it in directly to the battery so both lights can be on. However when I tun them both off the battery overcharge light comes on.
