125-200cc XC150 float question
Discussion in '2 Stroke' started by dingodog, Jun 7, 2015.
  1. dingodog Husqvarna
    The Garden State, Au
    '73 CR125, '82 WR250,
    XC150
    Hi there. Bike has been sitting idle for a couple of months during a refurb of bearings etc, fuel tank removed and carby dry. Bike now complete but leaks fuel from carby drain when bike is on a slight lean, it drips even when engine is idling. I have cleaned where needle makes contact with seat etc but no joy, any tips ?
    Thanks in advance DD
  2. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    stuck float? tap with screwdriver handle on carb bowl. float may need adjusting, may have been inadvertedly affected when playin with carb
  3. bsh7680 Husqvarna
    Cookeville TN
    12 CR 150
    04 PW 50, 08 KTM 50 JR Pro
    I had the same problem and adjusted my float about 5 times and could not get it to stop leaking. Finally bought a new float needle and problem solved. For some reason the needle as not getting a good seat. Maybe an extreme case but i wish I would have just bought a new needle and saved a lot of labor and frustration.
