125-200cc Yep..TOASTED
Discussion in '2 Stroke' started by pahusky, Jul 1, 2011.
  1. pahusky Husqvarna
    Hummelstown, Pa
    '14 TC250
    '12 250XC '09 1200GSA KLR650
    Got the top end and radiators all squared away only to figure out why we could not get a good plug read.
    Lots of extra air around the crank seal and the crank bearings are shot. After pulling the stator side cover I could move the flywheel up and down a click...
    Staying home for the weekend and drinking beer...not happy.[IMG]
  2. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    Oh well, drink a beer, split the cases, rebuild the bottom end and go racing.
  3. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Sorry to hear about that! Fyi, I. Used a prox rod kit from oem cycle $75 and the quality was excellent.
    I would put one in while you are in there and also because of the heat stress.
  4. Norman Foley Husqvarna
    Sorry you'll miss the National HS this weekend. I was thinking of going up to meet you. I hope to see you at Unadilla GNCC.
  5. montgob1 Husqvarna
    any idea of the # of hours on that bottom end? Have you thought about going with ceramic bearings for replacement?
  6. Vinduro Husqvarna
    Mississippi
    What brand oil were you using at what ratio ? Type of Gas ?
  7. pahusky Husqvarna
    Hummelstown, Pa
    '14 TC250
    Vin...klotz R50 @ 40:1, hi-test pump gas... We were out of town most likely 10% Eth.
    Did you see the other post here in discussions? A lot more info about the failure. Lost all rad fluid and cooked everything before heat seizure. The oil that tends to collect and reside in the valve holder area in the jug was cooked to flakeing...
  8. smoke229 Husqvarna
    IL
    sorry to hear about staying at home, we've been in your shoes in years past. if it wasnt for Halls we would of had to stay home once or twice this year!
  9. pahusky Husqvarna
    Hummelstown, Pa
    '14 TC250
    Kudos to all the dealers for keeping the bikes at the tracks!
    I'll give a shout out for the guys at Toy Tech Cycles...We thought we were on track with the repairs we made. Just not enough time and parts. The 4th is going to make it difficult to get a few key parts and shop work done. But we sat down at the dealer on Saturday, figured out what was in stock and what else we needed to order... We need to pull off a complete rebuild of the lower unit and be on our way to Ohio by Saturday.
    Wish us luck...
  10. montgob1 Husqvarna
    I have been able to source crank bearings and seals from my industrial vendors typically. Good luck
  11. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Good luck guys!
