Your favorite PCV for 2008-2012 Husqvarna Mikuni ECU models
Discussion in '4 Stroke' started by MotoXImage, May 20, 2016.
  1. MotoXImage Husqvarna
    Lake Arrowhead, California
    2017 FE 350
    2000 XR 400
    I have a couple of questions regarding the PCV I don't know what map comes in the Powercommander V #23-009. My bike is a 2011 TE310
    How do you connect a map switch? do you connect the switch to both map inputs using all four pins?
  2. Matthew525 Husqvarna
    New Berlin, WI
    2013 TXC 250R
    KTM 525, HONDA CRF150
  3. MotoXImage Husqvarna
    2017 FE 350
    2000 XR 400
    If I'm understanding this correctly, it looks like you plug a 2 way switch using 2 wires into the map 1 and map 2 posts. When you move the switch it will default to map 2?
    I was confused because a 2 way switch only has 2 wires and thought there were 4 map ports. Now I understand that the software makes the change assisted by the switch instead of a hardware connection making all the changes.
    Thanks Mathew525, you settled it quickly!
  4. MotoXImage Husqvarna
    2017 FE 350
    2000 XR 400
    I neglected to include the word map in my title. It should have read,
    Your favorite PCV " Map"
    For any, 2008 thru 2012 250, 310, 450 or 510 model with a Mikuni ECU
  5. Matthew525 Husqvarna
    New Berlin, WI
    2013 TXC 250R
    Basically if you hooked a wire from map port to map port you would select map 2.
    With no jumper map 1.
    Any latch open closed switch will work. I used a cheap RadioShack one.
    MotoXImage likes this.
  6. Mik-3 Husqvarna
    Finland
    Husvarna SM510R 2010
