04 TC 450 boggs down when warm
ccoates
bike starts fine and idles but after i take after about three min. it will bog down and die. i pulled the carb and everything looks clean and i have 175main and 30 pilot and iam at 3000ft elevation. i did see that float needle valve was stuck and fuel leaking from carb when petcock left on. will this flood out the carb hence bogging down and hard to start after riding for 3-5 min? any help would be grateful!
In short...Yes it will cause problems as the engine becomes flooded. You need to replace the needle and reset the float height.
Paw Paw
I could never cure my warm bog on my 04; i was about to pull the trigger on a Lectron after a summer of working on it didn't help. Carbs aren't a big mystery to me, either. Instead, I sold the 04 and bought an 05 with the Mikuni and it is an entirely different bike. Strong as an ox, quick to pick up the front, but most critically, completely smooth. There are NO gaps in power delivery from the bottom to the top of the range. I can't stress how much better of a bike this is solely for that reason.
