05 TE250 with 310 kit won't idle
ep13b
Hi
My brother recently purchased a 05 TE250 with 310 kit and over all the bike rides very well and goes nicely, but there is a nagging problem.
The bike won't idle at a reasonable level, it idles fine when you screw the idle screw up but the rpms are just too high, when you turn it down to reasonable level it makes a couple of pops through the airbox and then dies, I also noticed that after a rev it takes a few seconds for the idle to settle.
Any ideas on where to start would be greatly appreciated
Regards
Matthew
ep13b;120180 said:
Hi
Regards
Matthew
Check your throttle assembly, some times a pinch here or there can cause a hanging idle, if the throttle has very little freeplay this can affect the idle. Also if the carb is gummed up the idle may be affected.
Check your needle to make sure its in correct position and not set way too high,this will let the main circuit bleed over at idle.If that doesnt do it clean your entire carb.Since it has been apart may want to check cam timing?The needle too high or worn needle or emulsion tube is most common cause.These bikes do need to idle a bit fast its not an XR250.billf
