07 TC450 backfire
kev900sp
I'm a bit stumped, my 07 TC450 backfires constantly and kicks back when starting, sometimes violently. The carb and jets are clean, new intake manifold. Does anyone have any ideas or the number of a good Husky mechanic in the Phoenix,AZ area? Thanks for any advice you may have. Kevin
I have the same problem with my '08 TC510, and it takes 60 kicks to get it going, by then I'm ready to ride it off a cliff. Are you eventually getting it started?
First things I would do is seal the exhaust pipes with heat resistant silicone where they come together and check the valves.
It starts fairly easily, 4 or 5 kicks when cold with choke, the backfiring happens often when starting it hot. My son and I rode today for first time in a couple months and the popping was constant at pretty much all throttle settings. I'm having the valves checked next weekend and will seal exhaust pipe joints this week.
