08/09 TE 250/310 and EFM clutch
QwikSticks
Anyone with a 08/09 TE 250 or 310 have an EFM installed? Can you comment on how it feels?
I am looking for options. Rekluse no longer makes one that works in these bikes and Revloc has some wrinkles to iron out.
Thanks
Brian
I have an EFM auto in my 08 te250. very similar to feel as the REkluse in my buddys bike. Very smooth and progressive. More linear than the Rekluse EXP core in my TXC.
At what RPM do you feel the clutch start to engage to being fully engaged and do you ever feel any slip going from say 4500 RPM and cracking the throttle WFO? Are you still able to use your clutch at all?
Hard to say. I think it starts to engage around 2200 rpm just off idle and is fully engaged by 4000 rpm. The clutch pull is actually lighter than stock. Since I use it only for dualsports and don't ride it as hard as my TXC I can't speak to it's wfo endurance. However I have not noticed any slippage at high rpm hillclimbs. Works great.
Is this the auto or phantom version on your bike?
I really liked my EFM(not in a Husky though), bullet proof through 2 enduro seasons and play riding(2500+ miles). I had to play with setup... eventually I set it up slightly tighter than it called for and power was instant - NO drag at any speed. If setup loose it can ruin the plates.
I have one on my 09 310
nice
easy
adjustable full feel and override or do nothing with that lever on the left all day...the choice is yours.
I'm still waiting for my dyna-ring to come in. If alan can't straighten it out i will be tring the efm auto clutch.
Joe,
can you still lift the front tire in first through third? When your in 4th or 5th and your going to slow then crack it open does it lug its way up until its is happy with the speed again or do the RPMs shoot up to 10k and it slowly climbs in speed via slipping?
